Old 07-18-2007, 02:48 AM
fiki is on a distinguished road
Swing over bed (?)
hey all!
Can anyone please explain what actually swing over bed on lathes is?
Whats its corelation with max. turning diameter?
Some kind of diagram or picture with those dimensions could help alot...
Tnx!
Old 07-18-2007, 07:54 AM
skmetal7 is on a distinguished road
its twice the distance from the center of the chuck to the bed, or the max diameter a lathe can turn.
Old 07-18-2007, 08:09 AM
so according to you its the same thing? max turning diameter and swing over bed?
the thing is that different manufacureres seem to have a different definition for what swing over bed is. Because I saw a different values for max diameter and swing over bed on same machine. To be more confusing, sometimes max diameter is half the swing and sometimes is twice a swing...All i want is that all manufacturers decide what swing is gonna be
Old 07-18-2007, 09:08 AM
Not going to happen . The ones who make small lathes will probably use diameter because it sounds bigger.
Old 07-18-2007, 09:15 AM
svenakela is on a distinguished road
In the end it's the same thing, but the measurements are not.
Swing Over Bed is the radius. Max diameter is twice the radius.
On some machines the Swing Over Bed can be bigger than the radius as the tool holder can interrupt with the goods.
Regards,
Sven
Old 07-18-2007, 09:41 AM
for example...certain machine has max diameter 360 and swing over bed 600 mm...i know what max diameter should mean: that u can work on piece with max dia of 360 mm...right? and what does then 600 mm mean? that center of a tool holder can travel 600 mm from center of a chuck? or what? the thing is that i sell CNC machines and every manufacturer interprets that values diffrently..thats the problem so i only work with max diameter value because it means the same everywhere
Old 07-18-2007, 10:13 AM
Al_The_Man's Avatar
I always understood that the term swing in N.A. refers to the maximum turnable diameter, I believe in the UK they used to use the radius value for swing, which confused matters a bit.
There is also the swing across the cross slide and through the gap, if a gap bed lathe.
Old 07-18-2007, 10:40 AM
Swing over bed is the maximum size that can be mounted without hitting the bed. the max diameter in your example probably refers to the swing over the slide, the tool holder cross slide. The distance between centers or tool travel is something else, otherwise your provider messed the definitions up.
Old 07-19-2007, 07:12 AM
tnx sven...just wanted to see how many explanations can i get...since i deal with used machinery its a pain in a but, every dealer interpets differently and you get chaos in dimensions
but its little bit clearer now for me...
Old 07-19-2007, 07:49 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
Don't forget that sometimes max diameter can be given as dia in the GAP.
My large lathe is 36" X 168 but I can swing 44" in the gap (about 16" long) and only 30" over the carriage.
www.integratedmechanical.ca
Haas TL-3W? Big swing/bore CNC lathe recommendations sought rpseguin Haas Lathes 4 09-01-2007 12:22 PM
Swing Over Manual Lathe Questions griffithbuilt General Metal Working Machines 0 05-02-2006 11:36 AM
RFQ Swing Arm Cover rcazwillis Employment Opportunity 2 03-02-2006 11:35 PM
Swing on the IH mill? Roy Norris Industrial Hobbies (Support forum) 5 08-18-2005 01:12 AM
