Old 07-12-2007, 03:09 AM
drb_001 is on a distinguished road
Replacement Motor - Supermax VNM
Anyone know where to get a replacement motor for a Supermax knee mill? It is a YCM-16VS mill, according to the parts manual the motor is part number: 413062010. The tag on the motor says: Skykey Induction Motor, 3HP, 4 Pole, Design CNS-C112, 3Phase, 220V, 60Hz, 1720Rpm, 7Amps, Code E, MFG#00048944.
I can not find any reference or other help to get a new motor. If anyone can help with a cross reference or point me in the right direction I would really appreciate it.
Thanks!
Old 07-12-2007, 12:06 PM
Nevermind...
YCI Supermax has one in stock...$$$$=ouch.
Thanks,
Old 07-18-2007, 12:12 AM
SRT Mike is on a distinguished road
Sounds like a manual machine and you're looking at the spindle motor?
I can't help with where to get one but we had a Bridgeport with a big motor on it (maybe 5hp?). Well, a new one was CRAZY amounts of $$$ but we removed the unit and took it to a local motor shop. The guy rebuilt it and it worked like brandy-spanking new and I think it cost a few hundred bucks.
Unless it's totally cooked or absolutely destroyed, it should be repairable. Hell even if smoke and fire came out of it, so long as the case and some of the armature is good they should be able to fix it up - almost all the parts can be replaced. And a knowledgeable motor shop may be able to offer a non-Supermax-brand drop-in replacement that will be indistinguishable from OEM Supermax parts.
Can't hurt to try - look in the yellow pages under "motor" and see what you come up with. Good luck.
Old 07-18-2007, 12:21 AM
Al_The_Man's Avatar
The specs are for a standard 3ph 4pole AC Motor, so as suggested, I would think the cheapest/quickest way would be to try and get it re-wound.
CNC motor replacement/repair intellec7 Servo Motors and Drives 7 06-28-2010 09:30 PM
Eldorado Motor Replacement giantcake Shopmaster/Shoptask 2 05-29-2007 07:24 PM
Fanuc AC Motor replacement asuratman Fanuc 0 09-22-2006 08:32 AM
Spindle Motor replacement? Trapper14 Mini Lathe 3 03-10-2006 05:48 PM
Need stepper motor replacement help ProjectCNC General Electronics Discussion 2 01-29-2004 04:14 PM
