  #13   Ban this user!
Old 07-23-2007, 09:53 PM
carbidecraters's Avatar
carbidecraters is on a distinguished road
Originally Posted by ConKbot of Doom View Post
How so? Ive seen them used quite successfully on a few vertical mills. They clean off excess coolant in production work.
Load the fan, spin it up, move down, move across the table a few times to blow off all the coolant, up, stop, change pallets. Enclosed machines only of course.
Seems like you would have chips go where they shouldnt when your not carefull and blowing from the front. Seems like it *may keep chips out of the tool changer if you have a carousel type changer but it seems extremely hokie
  #14   Ban this user!
Old 07-23-2007, 09:58 PM
ConKbot of Doom is on a distinguished road
Valid point, if you aren't using enough coolant to sweep away the chips, and depending on how enclosed your 'enclosure' is. The fadal's Ive seen would just make a mess with this wouldn't nearly be as suited as the matsuuras Ive seen where the enclosure really does close off everything except a bit around the toolchanger.
  #15   Ban this user!
Old 07-23-2007, 10:57 PM
When my machines are running full tilt they are spreading chips everywhere and anywhere inside the enclosure.
I don't see how a fan could find any other places to blow them .
Cleaning off the grease Involute Syil Products 5 04-16-2007 01:36 PM
Cleaning of Ballscrews zoeper Linear and Rotary Motion 4 08-08-2006 01:52 PM
Cleaning out shop #2 SisuJeff Servo Motors and Drives 3 01-29-2006 12:11 AM
Self cleaning Filter Rance DIY-CNC Router Table Machines 5 01-18-2006 11:58 AM
End PCB cleaning drudgery MrWild General Electronics Discussion 6 11-13-2005 12:18 AM
