Old 04-21-2004, 01:47 PM
pfeist is on a distinguished road
Stepper Torque required for 7x18 Mill/Drill (Acme Screws)?
I"m plotting and scheming to retrofit my older Enco Mill/Drill to CNC...
One unresolved question is;
How big a stepper motors do I need?
I want to start out using the standard acme screws.. they're smooth and I've laboriously adjusted all but a tiny bit of backlash out of them..
I'll refit with ball screws eventually, but I"m poor.. so I want to concentrate on the electronics end first.
Is 400 Oz-In for X and Y "enough"?
More is better, but I don't want to grossly "over-motor"...
Thanks for yout thoughts!
Paul F.
Old 04-23-2004, 06:30 AM
RotarySMP's Avatar
RotarySMP is on a distinguished road
You have a few approaches available:
1/ 400 ozin motors, if they are geared, can move just about anything, and will definitely provide enough thrust* to mill with, although you may be disappointed by the rapids.
2/ You can search the web for someone who has done the machine you want to convert, and then size your motors based on their recommendations.
3/ Use a fish scale to measure the force you apply to the hand wheel, then multiply it by the radius to get the torque you are applying. Design a belt reduction system to convert your 400 ozin to your target.
4/ Here is the method suggested by Marriss :
http://groups.yahoo.com/group/turbocnc/message/1968
* 400Ozin doesn't really describe a stepper. You really want to know what power it produces, eg, a 10V 1A Nema34 might produce 400ozin peak torque but have a torque curve that drops off a cliff, meaning low power, and thus low rapids. As a rule of thumb you are looking for Nema 34’s with the highest Amperage your drivers can supply. These have much flatter torque curves.
Regards,
Mark
www.wrathall.com
Old 04-25-2004, 09:27 PM
RotarySMP/Mark;
As with your post to my other question/thread, that's exactly what I needed!
Thanks!
Now I at least know how to start deciding what sort of motor power I need.
Paul F.
Old 04-26-2004, 01:56 PM
HomeCNC's Avatar
HomeCNC is on a distinguished road
I use 430 oz/in servos on my Enco drill/mill connected at a 2:1 ratio. I can snap off 3/8" end mills with my .200 pitch ball screws.
Jeff Davis (HomeCNC)
http://www.homecnc.info
Stepper motor torque problems? Chris D Stepper Motors and Drives 4 06-07-2005 01:15 PM
Stepper Motor High Torque Low Amp Sanghera Stepper Motors and Drives 13 03-21-2005 06:16 PM
Motor calculations jevs General Electronics Discussion 25 03-21-2005 01:05 PM
Stepper question: torque re: current cnczane Stepper Motors and Drives 14 10-21-2004 08:30 PM
Acme screws as linear rails? bb99 DIY-CNC Router Table Machines 4 12-26-2003 03:24 PM
