Old 07-04-2007, 11:02 AM
Dee Bee is on a distinguished road
Ikegai FX25n spindle range shift
Does anyone know the M code to get the high-low clutch on a FX25 to change? I can get it to change using the manual controls but not in a program. A 1500 rpm speed will stay in high when given a 200 rpm command. The spindle will slow down to the commanded speed but, will stay in high range. I need a shift for the torque. I'm thinking an M code for the range shift? The control is a Fanuc 5T Thanks db
Old 07-05-2007, 01:58 PM
wcopley's Avatar
wcopley is on a distinguished road
Probably m41 low gear
m42 high gear
Old 07-07-2007, 02:13 PM
I just tried M40 to M45. No luck db
Old 07-07-2007, 04:35 PM
gridley51 is on a distinguished road
Can`t help with the Ikegai but I have a couple of machines that use M90-M91.
There is a guy called radius over on the PM forum who just got a FX20 which I don`t think has a gearbox but his manual might list all the machine builders M codes and each builder usually sticks to the same codes across his range.
Mark.
Help! Ikegai FX-20N and Fanuc 5T problem! Radius General Metal Working Machines 2 05-29-2009 11:42 AM
Ikegai FX20N lathe gridley51 General Metal Working Machines 9 11-17-2007 06:19 PM
Ikegai TV-4 machine M06 not working. Ashu CNC Machining Centers 23 09-26-2007 09:47 AM
How much does an Ikegai FT20U weigh? protrxrptr17 General Metal Working Machines 1 12-13-2006 07:39 PM
Spindle speed range or lack of it! creep_pea Bridgeport and Hardinge Mills 7 10-04-2006 04:42 PM
