Old 06-25-2007, 12:41 PM
Crashmaster's Avatar
Crashmaster is on a distinguished road
Question How to Switch Gears on a Lathe
Had a repair guy come out and fix a problem I was having with my Wasino Lathe. He fixed it but left the lathe in low gear. I have never run it in anything but high gear and have no idea how to switch it. Is it a code you input into the control or a parameter or something else. Any help would be appreciated. It has a Fanuc 10T control. Thanks.
Old 06-26-2007, 12:05 AM
CNCRim's Avatar
M41 high
M40 low
M code for each manufacture is little difference so check your manual.
Old 06-26-2007, 07:06 AM
Yup, that did it. Thanks.
Wanted Enco Lathe Model 110-0818 SWITCH chrysler48 General Metal Working Machines 1 08-31-2011 04:02 PM
limit switch and home switch setup Runner4404spd General Electronics Discussion 0 12-15-2005 07:58 AM
Is it possible to use the home switch as the limit switch as well? Darc Mach Software (ArtSoft software) 2 10-23-2005 12:50 AM
Limit Switch / Home Switch in Software Sanghera General Electronics Discussion 6 11-01-2004 05:58 PM
