Old 06-23-2007, 02:42 PM
simonfilm is on a distinguished road
Chuck that drops...
I have just bought this machine http://www.weiss.com.cn/products/wmp250v.php
It comes with the chuck I show on the picture. I attach it to the Morse taper with a nylon hammer, but as soon as I use it a bit it drops. Excuse me for my ignorance.
What do I do wrong?
Thank you very much!
Simon.
Old 06-24-2007, 09:00 AM
snowshovelbmx is on a distinguished road
in the picture that is not the morse taper that is commin off it is teh jacobs taper and it is more of a permenent locking taper, what you can do is heat the drill chuck up a little bit( doesn't need to be a lot) and then tap it onto the taper. as it cools and contracts it should set better. Also make sure that both the spindle and chuck tapers are free from and dirt.
chris.
"you don't even need cnc if your handy with a torch"
Old 06-24-2007, 09:15 AM
Did it come off while you were drilling or did you have a milling cutter in the chuck?
Even if you heat and tap the Jacob taper together it will come off when you try to use a milling cutter and put a side load on the chuck.
Old 06-24-2007, 09:27 AM
svenakela is on a distinguished road
Isn't there a threaded hole in the center?
My chucks are fixed with a screw in the bottom into the axle.
Regards,
Sven
Old 06-24-2007, 11:08 AM
DJPLAST is on a distinguished road
This fit MUST BE CLEAN and no burrs, no nicks, no rings from "spinnig" the shank in the taper. Once these two pieces are wrung together they usually stay together and are a bear to get apart. If you have spun the arbor into the chuck, then more than likely you need a new shank. The chuck is hard and usually survives, but the shank usually gets the damage.
Old 06-24-2007, 02:13 PM
skmetal7 is on a distinguished road
i usually give mine a good WHACK with the chuck resting on a piece of wood, and a piece of wood between the arbor and steel hammer (hasnt came off yet)
Old 06-24-2007, 02:14 PM
One of Many is on a distinguished road
If you are milling with a chuck, it should at minimum have an integral shank. If a mating shank and bore do not match the full taper, it can walk apart more often than not as it shifts about on the slightest mismatched taper while spinning against a side load.
A keyless chuck as a side cutting tool holder is asking for trouble. It is not a case of IF they open up, but given a combination of vibration and side loading, they can and WILL open at the least convenient moment. Even a keyed chuck can have similar problems, et al with less probability. Although a keyless chuck is designed to self tighten under constant thrust loads, initially it won't ever be as tight as a keyed chuck.
You can blue up the tapers to inspect how much bearing surface is actually doing its job. Then alter the shanks Jacobs taper hi-spot areas to get better than 80% contact. This still won't end the limitations of a 2 piece chuck and milling.
DC
Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade.
Old 07-10-2007, 02:00 AM
gsrmmeza is on a distinguished road
there are many different tapers for drill chucks. do you
know if your chuck is the correct chuck for that taper.
the chuck will have a number letter combo on it some where.
it can be any of the following j1,2jt,6,6jt,33jt, or many
other sizes. you will need to check that the male(quill) is
the correct mating taper for the female(chuck).
Old 07-18-2007, 07:02 PM
ironDigit is on a distinguished road
try drilling the largest hole you can in a he thickest piece of scratch steel for as deep as you can. hmmm given this is the correct shank for your chuck and your not including to much oilr/grease it is now "permanently"fitted to its arbor by the axial load from the drilling.
Hoe to get it off again : i never succeeded in taking mine off but why would i want that to anyway i can't imagine a job requiring a chuck without its arbor.
And yes i keep a seperate chuck for any machine that i would like to drill anything with.
just my 2cts.
Old 01-01-2009, 08:40 PM
parttime is on a distinguished road
I have a similar problem. My MT2 taper spun in the quill tube. I can replace the taper for about $10. What should I do about the quill tube? I am considering using some sort of abrasive to file the burrs while I run the machine. (of course I'll keep my fingers and eyes safe doing it).
Q: Need 5C Chuck Deviant Mini Lathe 1 04-23-2007 03:15 PM
Chuck Drill Chuck Alignment TomV Mini Lathe 5 04-27-2006 01:20 AM
T-Slot Aluminum Drops 80/20surplus Product Announcements & Manufacturer News 3 08-10-2005 04:28 PM
