Old 06-22-2007, 10:24 AM
Crashmaster's Avatar
Crashmaster is on a distinguished road
Tumblers Effect on Nearby Machinery
Does anybody know if a 1HP Vibratory Tumbler will have any ill effects on nearby
Machinery. Specifically a CNC Lathe and CNC VMC? I know this is probably a reach but I just want to be sure the vibrations aren't going to throw my machines out of whack. Thanks.
Old 06-22-2007, 11:37 AM
pastera is on a distinguished road
The effect will depend on how the machines are mounted and how stiff your floor is but I would say you will probably be able to detect a difference in finish quality if the tumbler is mounted close by. Depending on the parts it may be of no consequence (or could be a show stopper).
Aaron
Old 06-22-2007, 11:51 AM
mxtras's Avatar
Silver Member
mxtras is on a distinguished road
I suggest isolating the tumbler.
It's always best to isolate each piece of machinery, also. This is not usually financially practical, though.
Scott
Consistency is a good thing....unless you're consistently an idiot.
Old 06-22-2007, 01:02 PM
Well crap, I was hoping that wouldn't be the replies I got. The tumbler would be bolted directly to the concrete floor, it that matters which I am guessing it doesn't.
Old 06-22-2007, 01:21 PM
Probably makes it worse. The vibrations from the tumbler will pass directly to the floor if it is directly bolted. Put it on isolation mounts.
A crude way of providing even more isolation than just attaching the tumbler itself to the floor with isolation mounts is to get a heavy steel plate and mount this to the floor on isolator mounts then mount the tumbler on this again with isolator mounts.
Old 06-22-2007, 01:56 PM
Thats not a bad idea at all, and from what I can remember (which isn't a lot) is that isolation mounts are pretty cheap.
Old 06-22-2007, 02:20 PM
And I am sure I have seen them advertised on CNCzone.
Old 06-23-2007, 12:22 PM
Found the link;
http://www.vibrationmounts.com/
Old 06-23-2007, 12:46 PM
MDLang is on a distinguished road
I'm sure vibratory mounts are a not bad idea but I highly doubt that a 1 HP tumbler is going to effect anything but a CMM.
That VMC your worried about is capable of creating some real vibrations.
I wouldn't worry about it myself.
Standard just my opinion disclaimers apply.
Mike
Old 06-23-2007, 01:49 PM
Because it runs at a constant speed for extended periods even a small vibratory device can create significant floor bounce if it happens to hit on a resonant frequency. Sort of like a mouse pushing an elephant on a swing, time the little pushes just right and the elephant gets a good ride.
VMC may create stronger vibrations but they are not as constant and often only short lived.
Old 06-23-2007, 02:13 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
i would think a tumblers vibrations would definitely affect the accuracy of the machines ,
we ve had one job in particular where we needed to uphold bores on a bcd within a .0003 positional tolerance ,which proved to be dificult when the large mill on the other side of the floor was running the 4" shellmill (hogging), the vibrations threw things around some , not anything work worrying about under normal circumstances , but in tight times when even the machines own tolerances are trouble enough ,you don t need the extra headaches
What effect does microstepping have on torque? Stuff-Builder Stepper Motors and Drives 64 04-05-2012 04:43 AM
Vibratory tumblers the way to go? msomerville Mass finishing equipment/media/stratigies 7 01-20-2007 08:39 PM
Cycle pause in effect? What? wildcat Mach Software (ArtSoft software) 0 12-02-2006 05:28 AM
minitech machinery Please Help! gone4pepsi CNC Tooling 6 12-01-2006 10:49 AM
Effect of T0 (tool offset cancel) HuFlungDung CamSoft Products 5 09-01-2006 03:58 PM
