Old 06-20-2007, 03:05 PM
phantomcow2 is on a distinguished road
Collets for Jet 9" lathe
Hey, does anybody know what size collets are used in the Jet 9" swing lathe? Also, could what is a suitable collet closer assembly for it? Thanks
Old 06-21-2007, 09:11 AM
S_J_H is on a distinguished road
The jet 9" is the same as any other import 9x20. The headstock has a MT3 taper and it will have a screw on chuck. You probably would not want to bother with mt3 collets. Can't put stock all the way through and they have a very low size range per collet. You might be able to find a 5c chuck that will fit. I'm not sure though. Otherwise you'll have to make your own.
I made a er32 chuck for my Grizzly 9x20. Works great.
Steve
CNC "KIT" for 8x12 8x14 mini lathe - or cheap/small CNC lathe? tinkering Mini Lathe 15 05-05-2011 05:59 PM
Homier 7"x12" CNC Mini Lathe on Ebay whiteriver Mini Lathe 0 04-15-2007 06:33 PM
12"X30" Lathe on Ebay, $1000 - good deal? mxtras General Metalwork Discussion 2 06-24-2005 10:12 AM
mini lathe collets cncfreak Mini Lathe 2 05-29-2004 08:55 PM
Portor Cable Collets 1/8" and 3/16" whiteriver DIY-CNC Router Table Machines 18 01-09-2004 10:51 AM
