Old 06-19-2007, 09:42 PM
IN-WondeR is on a distinguished road
Retrofitting a Beaver NC5
I have gotten myself a Beaver NC5, but the old NC controls and all is gone, So I'm going to fit it with new motors, CNC Controls, driver powersupply's and all that..
But I'm a little out of ideas to how big the motors should be for it, I have an option to buy a complete kit with 3 motors and 3 drivers and power supply's and all. But is 3Nm enough for such a big machine.???
Or should I go higher..???
Old 06-20-2007, 04:32 PM
Is there no-one who has an old big milling machine who can tell me what they have used of motors... How much torque have you put on your milling machines...
Old 06-20-2007, 05:13 PM
Karl_T's Avatar
Karl_T is on a distinguished road
What you're happy with depends a huge amount on how hard you want to push the machine.
I have a similar mill with 2400 oz/in steppers and 12 amp stepper power supplies. Many are happy with steppers 1/2 that size and gecko supplies also with about 1/2 the power.
I'm planning on upgrading my machine to servos with a slightly larger torque rating. But servos don't lose torque at higher rpm so I should be able to get higher rapid move speeds. I can only rapid at 50 ipm right now to be sure I never lose a step.
Karl
Old 06-20-2007, 05:48 PM
rapid move speeds, you mean jogging speed.???
I'm not planning on running the machine harder than needed to make the parts that it's going to make.. I have the 3 original motors that it came with though, but I'm not sure what they are, if they are servoes or steppers, and if there's encoders built in or what...
In about 4 weeks I will recieve the machine then I will know much more at that time... Until then I'm a little in the dark...
Old 06-20-2007, 08:43 PM
Gold Member
Adobe Machine is on a distinguished road
Jeez, I have an English Beaver from the '40s or 50's that I put a WEBB mill head on in the 70's..still works as a nice drill press and the X axis has a built in axis motor..
I run my Tree converted Mill (Circa 1978, 10"x52") with 670lbs/inch servos at a 5 to 1 belt reduction..rapids =140-150 IPM, cutting speeds vary with material, but I do not think I have ever been over 45-50IPM cutting speed comfortably, with .0005-.0007 accuracy..Is this a Hobby or pure production machine ?..Faster does not =better.
Adobe (old as ddirt)
Old 06-20-2007, 08:56 PM
As said, i'm not going to goe faster than any material allows me, but off course I don't want to go 1 inch a minute, but the jogging speed should be high so I don't have to wait 5 minutes for it to return to zero point...
I'm gonna go with a set of 8.5Nm steppers, cheapest for me contra servo motors... And somewhat easier for me to get a hold of...
For now the machine will only be hobby, but in time, who knows what will happen along the way... I'm currently trying to get a good machine shop together..
Pratt & Whinety Beaver 5 mansuper CNCzone Club House 1 07-30-2011 04:42 AM
Pratt & Whinety Beaver V mill mansuper General Metal Working Machines 0 10-31-2006 09:52 PM
Beaver NC5-ATC arena Machine Problems, Solutions , Wireless DNC, serial port 4 09-03-2006 01:44 PM
Retrofitting a Bridgeport kuchean Servo Motors and Drives 14 07-24-2006 01:46 PM
Retrofitting a Mazak HMC jorgelr General Metal Working Machines 1 06-01-2006 11:16 AM
