Old 04-13-2004, 10:16 AM
Swede's Avatar
Swede is on a distinguished road
R8 Quick-change recommendations
Once again I look to the Zone members for advice!
I am doing a serious upgrade to my knee mill. The VFD and new motor is part of it. I am going to keep this mill as a manual machine, and I really would like to set it up for hand-swapped QC tooling.
I know Royal makes one. I haven't done a lot of research on these systems, I'd rather hear from guys who have actually used them.
My goal is to have a master adapter for my R8 spindle, and start out with a few 3/8", 1/2", and 3/4" shank EM adapters, a drill chuck or two, a boring head, pretty much the basic tools and cutters I use frequently.
Any brand names you guys can toss out? Preferably ones I can "steal" on eBay?
Swede
Old 04-13-2004, 11:43 AM
Al_The_Man's Avatar
The two Excello mills I have are Universal 300 Kwik change, I don't know how these compare with R8, but there is usually alot comes up on ebay at good prices. These are secured by 'C' spanner/nut system, they do not have a drawbar, which is probabally fastest.
Al
Old 04-13-2004, 11:51 PM
DLMACHINE is on a distinguished road
Check with your Bridgeport parts supplier, some Bridgeports came with a Quick Change 30 taper spindle. You may be able to come up a set up for your machine.
Old 04-14-2004, 01:01 PM
Swede's Avatar
Thanks guys. My mill is not a BP but rather a clone. The ideal answer would be a 30 taper with a pneumatic drawbar, or a Kwik-switch spindle, but I suspect I'll end up going for an R8 adaptor, which will produce a bit of overhang. I tend to not push this machine hard, so that shouldn't be too much of a problem.
Old 04-16-2004, 09:59 AM
nervis1 is on a distinguished road
I use the Royal system for a while in a home built CNC. It is very well made, and very easy to use. I could do a tool change with one hand in 2 seconds. The only problem was when the program was long the spindle would get hot, had to wear a glove a few times.
got bored today Quick change knurl Rainman229 Mini Lathe 8 11-29-2005 12:12 AM
Quick change router bit wjbzone DIY-CNC Router Table Machines 13 06-07-2005 12:56 PM
Quick change tool system (milling) mark c General Metal Working Machines 3 02-17-2005 06:50 AM
Quick change toolpost Klox General Metalwork Discussion 3 01-10-2005 12:38 PM
Quick change head design kdoney DIY-CNC Router Table Machines 1 07-05-2003 11:57 AM
