Old 06-14-2007, 04:46 PM
pruettc is on a distinguished road
Need info about this shear
I bought this shear used and the only name on it is Nelson. It's supposed to be capable of 16ga. the width of the bed is 48"
Can't find anything on the net for a company called Nelson and called several other companies such as Tennsmith and nobody has ever heard of them.
I'm looking for general info about the shear it will shear 16ga in narrow widths such as 6" wde but stalls out on wider pieces.
The shear is air powered ( I guess air over hydraulics?) I noticed the hydraulic res. is about half full. I am curious if this needs to be filled and with regular hyd. fluid or a special kind for cylinders powered by air. Any info anybody can give me I really appreciate
Chad
Name:	101_9485 (Small).JPG‎
Old 06-18-2007, 09:08 AM
jockey is on a distinguished road
It looks a lot like a Pexto shear. The base, hold downs and such. Probably more of a 18 gauge shear. If you replace the cyl's you will be closer the the 16 ga range.
MasterCam for a CNC Press Break & Shear? Miguel Gonzalez Mastercam 4 05-23-2007 12:26 PM
CNC Press Break & Shear Miguel Gonzalez Bending, Forging,Extrusion... 0 05-14-2007 02:16 PM
Dro for a shear Turbo67cnc Calibration & Measurement 1 05-14-2007 03:37 AM
pneumatic sheetmetal shear 307startup General Metal Working Machines 3 02-15-2007 09:53 AM
Selection of tool steel - shear InspirationTool General Metalwork Discussion 6 07-12-2005 08:41 AM
