Old 06-14-2007, 02:44 PM
olhippiebiker's Avatar
olhippiebiker is on a distinguished road
Dynamyte 4400
Help! We have a Dynamyte 4400 mill that we are trying to retro fit with a different control and still use the spindle controls and draw bar. We've managed to get past the homing start up operation for the X axis and still run the spindle and tool clamp. However, when we by-passed the Y and Z axis nothing worked. The screen is blank and you cannot enter any info or programs. After switching it all back nothing still works. Have we blown a board or what? We're pretty electronicly challenged and have no idea what to try now.
Old 06-14-2007, 02:59 PM
Gold Member
Caprirs is on a distinguished road
What parts are you replacing? What do mean "by-passed" the Y and Z axes?
Old 06-14-2007, 08:37 PM
The machine 's start up cycle always homes the axises out. If it doesn't home it won't go. We jumped the limit switches so that it thinks it has homed out. Everything worked fine when we tested it with the X axis, but when we did all three, it just won't do anything. You cannot input any data.
Old 06-14-2007, 10:51 PM
Gold Member
I'm guessing, but it's possible that some of the home switches are normally open type and others are normally closed. You might want to check with a meter to see which state each switch is in before jumpering.
Old 06-15-2007, 08:27 AM
When we put everything back to the original conections the machine still wouldn't work. The control panel will not allow any input. That's why I'm afraid we fried something and just don't know what board or fuse or whatever.
Old 06-15-2007, 08:10 PM
Gold Member
There are a couple fuses on the side of the back cabinet. They are accessed from the outside by rotating the "knob" a quarter turn and the fuse will pop out.
Do you get "Ready?" on the control screen at all?
Old 06-16-2007, 01:02 AM
No. All the LED lights on the controller come on when you hit the start button and then it just freezes up and you can't get to any screens. Absolutely nothing will work, tool clamp, spindle control or way oilers.
Old 06-16-2007, 10:29 AM
Gold Member
Yeesh. I think you'll have to call Dyna in California. It's possible some board got fried. You can get their number from their web site www.dynamechtronics.com
Old 06-17-2007, 01:30 AM
Yeah, that's what I was afraid of. Thanks for the help.
Old 06-17-2007, 02:59 PM
widgits is on a distinguished road
Don't give up just yet
First of all what type of controller are you trying to replace?
Most machine controls won't let you do anything till you home out the machine
If you still have a display that's a good sign
But have you double checked the limit switches and the settings for
travel to these switches
What type of drive motors does this machine have? DC servos?
Have the encoders been replaced?
Do they give you a correct square wave output on all 3 axis?
Go back and double check everything
Widgits
Old 06-17-2007, 04:24 PM
Gold Member
This Dyna has Dyna's SKIP control (single key input programming) and uses stepper motors with encoders on the motors. Upon power up, the control's LCD prompts "Ready?" and the operator presses a key to begin the home sequence. Only after all three axes home successfully will the control allow the operator to do anything else.
  #12   Ban this user!
Old 06-18-2007, 09:03 PM
Any ideas on how to by-pass the spindle break and power the oilers and tool changer? I know absolutely nothing about electronics and haven't had much luck finding anyone who will work on the Dynamytes.
Dyna 4400 pst help JWWalthall Post Processors for MC 4 12-15-2010 05:38 AM
Dyna Mechtronics 4400 Professorwiz Machine Problems, Solutions , Wireless DNC, serial port 4 05-19-2006 02:52 PM
Need Info on Dynamyte 2400C Rico55 Benchtop Machines 2 03-06-2006 04:53 PM
Dynamectronics 4400 Ernie General CAM Discussion 1 08-08-2003 03:05 AM
