Results 1 to 4 of 4
Thread: Getting into Micro-Machining
    Registered adaptforge's Avatar
    Mar 2004
    Where does one begin to research micro-machining?
    Mar 2004
    www.google.com
    On a more serious note, a lot of micro machining isn't actually machining. The really small stuff uses photo lithography similar to how they make transistors. EDM is common aswell but can only do larger parts (by micro standards).
    Mill's don't come close to the kind of accuracy you need, even the vibrations they make will wreck the part your making.
    Registered ImanCarrot's Avatar
    Nov 2005
    UK
    Very true....
    However... this is what I do:
    http://en.wikipedia.org/wiki/Diamond_turning
    I can get +/- a couple of microns easy peasy (that's a thousandth of a millimeter) and nanometers are a familiar phrase in my lab hehe.
    Vibrations from the factory next door does cause surface finish problems when they drive their forklift about though.
    My machine is vibration isolated though, on an epoxy granite plinth which rests on air pads- all the axes are floating on air too and the spindle is an air bearing spindle (temperature controlled)... my digital readouts go to 5 decimal places in millimeters... if you prod the axes with your pinky the readouds change
    Hehe it can be done if you spend enough cash.
    Vibration is my hated enemy lol and if the temperature in my lab changes by 2 deg C it messes everything up.
    However, the best bit of equipment I have is a little bit of wood next to the machine which I touch for good luck every time before pressing the big green button!
    I love deadlines- I like the whooshing sound they make as they fly by.
    Apr 2007
    The diamond turners are definitely a "special" group of people. No one else really understands or believes what they do works either, but we all enjoy the fruits of their labor.
    Anyway, another area a bit closer to what you are probably thinking is related to MEMS. Here is a wiki link.
    http://en.wikipedia.org/wiki/MEMS
    I am involved in electron beam lithography, so feel free to contact me if you need some help in that area. We have access to line widths in the sub 5nm range on a contract basis.
    Interestingly, one of the largest users of MEMS is the car industry for air bag sensors.
  1. Bosch CNC Micro 5
    By Olsson in forum Machine Problems, Solutions , Wireless DNC, serial port
    Last Post: 03-17-2008, 03:11 PM
  2. RC Micro heli.
    By MrBean in forum Parts for Radio Control Models
    Last Post: 08-10-2007, 11:38 AM
  3. Machining anodized parts or anodize after machining?
    By SRT Mike in forum General Metalwork Discussion
    Last Post: 03-12-2006, 12:22 AM
  4. Micro Mark
    By xa_shall in forum Mini Lathe
    Last Post: 11-10-2005, 05:24 PM
  5. micro-edm
    By roysol in forum General EDM
    Last Post: 10-15-2003, 02:01 PM
