Old 04-11-2004, 11:19 AM
gcamlibel is on a distinguished road
OPTIMUM BF 20 Vario Mill Made in Germany
Is there any forum reader who know something about this mill?
I live in Turkey. In my country only OPTIMUM BF 20 Vario is possible to puchase as small mill. We can not buy from USA becouse of high tax rates and shipping costs.
This machine can be seen at http://www.optimum-maschinen.de/opti_neu/home/home.html
(please chose FRASEN from left menu and than OPTIMUM BF 20 Vario to see this mill)
I am waiting for suggestions.
Gunol Camlibel
gunolcamlibel@rc-tuning.com
http://www.rc-tuning.com
Old 04-11-2004, 12:47 PM
*Registered*
ESjaavik is on a distinguished road
Russia is not very far from you. Maybe you should look at this:
http://www.fasie.ru/erten/index.html
Hopefully their machines works better than their web site! I checked it now and could not get further than the main page. But I've seen it before and it looks extremely versatile. It's a lathe / mill combo with quite another twist.
Here is another link that seems to work: http://www.industrialageworkshop.com/IAWErten.html
Old 04-11-2004, 01:05 PM
yes you are right about their home page.
I could not open their web site.
The combo machine at second link is very interesting.
Thank you for advice.
Gunol Camlibel
Old 04-11-2004, 04:30 PM
IJ. IJ. is offline
Gold Member
IJ. is on a distinguished road
The BF20 looks to be the same as what is available worldwide from most machinery sellers. (HF/Grizzly/Hafco) They're made in the same factory and the only differences seems to be paint colour.
I have been using one of their slightly smaller Mills for a few years now and it's been reliable and accurate and I'm very happy with the purchase, I'm purchasing another Mill around the BF20 size this Wednesday to use as the base of my CNC conversion.
(That Russian MC is an interesting concept, just wondering about rigidity though)
Old 04-12-2004, 12:39 AM
NeoMoses's Avatar
NeoMoses is on a distinguished road
gcamlibel, would you mind translating some of the specs for that machine? From what I can tell, it should work very well for you. It appears to be very similar to the machine I converted about a year ago, you can check it out in the Gallery if you want.
If I'm translating (more like guessing in this case ) correctly, the machine has a 600W (~0.8 HP) motor and has spindle speeds in the 100-3000 RPM range. (Please correct me if I'm wrong) That motor size may be a bit small depending on what you plan to be cutting. It looks like the RPM is digitally controlled (probably a VFD DC motor on the spindle) which would be a nice option rather than belt or gear drives. I'd say it looks like a safe bet; I'd be willing to pay up to about $1500 US dollars for something like that.
Let us know how you decide.
My name is Electric Nachos. Sorry to impose, but I am the ocean.
http://www.bryanpryor.com
Old 04-12-2004, 12:47 AM
I copied BF20's user manual from a store at Ankara. I will attach its specifications page here. I think it will be better than translating the web page.
Gunol Camlibel
Old 04-12-2004, 12:48 AM
I devided page into two parts becouse of the post size limitation.
here is the second part.
Gunol Camlibel
Old 04-12-2004, 02:36 AM
*Registered*
Here what is said on a competing board(The Google cache so you don't have to join as member):
http://66.102.9.104/search?q=cache:9...hl=no&ie=UTF-8
For those not reading german, the ultra short version is that one guy there bought it and his first impressions are good. It is also rumored that the first versions smoked their speed controllers. The guy wrote he got it with a test certificate and checked himself that it actually was within the pretty decent specs. The slides were scraped, in itself a sign that the producer at least put some pride in it. It was also said on this board that you could hear the electronics regulating. Some real cheap ones will just output a frequency (if VFD) or voltage (if brushed DC) and not compensate for any load.
I found this mill interesting too as I might like to have a "laptop mill". And if it is using BLDC and not brushed DC motors, then it might give good performance for the stated HP. I found nowhere saying that it has though, so assume it is brushed. If youy buy one, please keep us updated! At Eur. 1K I might be interested in picking one up myself next time I'm in Germany.
And don't believe the specs! The German version just states it has a drilling capacity of 20mm, not that it will do it in steel. The motor output is 440W (http://www.hh-motor.com/pro1-5.htm)+calculator. It has 0,785Nm@5500RPM. With a slow speed max of 1500 it must be geared down 1:4. That means you have 3,14Nm at the spindle. You don't drill 20mm steel with that kind of torque. This does not make it a bad mill for the money though, it just shows that some sales people believe the customer is an idiot.
Old 04-12-2004, 05:00 AM
Thank you for your warnings and advices.
I read motor specifications at chinese site and I also read "peters cnc ecke" forum. I can not understand German but I have Systran Translater installed to my pc which can translate German sites to English. I found lots of material about BF20 vario at this forum.
Today I checked the local stores at Ankara to learn if this mill is available or not. But I could not find it here.
I learned who importes Optimum Machines to Turkey and I called that company. Unfortunatelly they said BF20 vario will available next month.
I will buy one when it is available and inform you.
Gunol Camlibel
Old 04-12-2004, 06:07 AM
IJ. IJ. is offline
Gold Member
gcamlibel: Looking at the specs you posted it's a much smaller Mill to what I'm getting on Wednesday!
The table size on mine is 230 x 1244, it's funny how the pic on their site is deceptive.
(Mine is more the MF2 size so maybe I clicked the wrong image)
btw: I think your chipboard CNC is brilliant !! !!
  #11   Ban this user!
Old 04-13-2004, 02:38 AM
I talk to importer of Optimum this morning. They said BF20 wil be available next week.
I will wait it impatiently.
It is written at specifications of this machine that it uses MT2 at English manual and MK2 at German manual. (and at the web site it is written as "MK 2 / M 10")
What does it mean? I think I shoud order tool holder seperately isn't it?
Gunol Camlibel
  #12   Ban this user!
Old 04-13-2004, 07:09 AM
Konstantin's Avatar
Konstantin is on a distinguished road
Wow the russian ERTEN machine is looking very nice.
I am russian myself and do russians never stop to amaze me with their versatility.
BV20 is chinesse making and for some reason chinesse hardware is tricky to buy, they are prone to use soft steels in their machines. Have to be that I am russian but I fell in love with the ERTEN lathe.
horizontal mill made by Tree PETE1968 General Metal Working Machines 6 02-22-2007 07:27 AM
Pictures of My Lathe & CNC MILL studysession General Metal Working Machines 14 01-04-2005 04:07 PM
Made In Germany ESjaavik DIY-CNC Router Table Machines 3 05-06-2004 08:53 AM
Home made CNC mill (and some products made by it) gcamlibel DIY-CNC Router Table Machines 23 04-05-2004 05:54 PM
How about this for a home made cnc mill? fyffe555 DIY-CNC Router Table Machines 7 12-23-2003 05:14 PM
