Old 06-06-2007, 06:39 AM
UKRobotics is on a distinguished road
Rotary Tables
Just wondering if is possible to modify a rotary table designed for horizontal use to use it vertically.
I'm thinking along the lines of a sizeable block of steel which I could bolt down to my x axis and then bolt the a axis on the side.
Is there any reason why doing this would be a bad idea ? It just seems horizontal rotary tables come up for sale more often and more less money than the vertical equivilant.
Dom
http://www.ukrobotics.com/projects
Old 06-06-2007, 11:17 AM
Dom, Depends on how it's lubricated. If it is a worm/wormwheel type they are often running in oil. Hopefully, if you position it out of normal attitude it will still be lubricated. Another potential problem would be lube leaking out. Good Luck
DZASTR
Trunnnion Table for Rotary Tables stanmms Product Announcements & Manufacturer News 0 04-30-2007 05:30 AM
Torque motors for rotary tables Fireflowers Servo Motors and Drives 0 04-01-2007 11:06 AM
Tool Tables mmorton9 Mach Mill 2 01-17-2006 04:01 AM
What do you think about these tables xairflyer DIY-CNC Router Table Machines 6 09-09-2005 07:23 AM
imported rotary tables vacpress General Metal Working Machines 8 04-06-2004 10:03 PM
