Results 1 to 6 of 6
Thread: How to tap a hole?
    Feb 2007
    Brunei
    How to tap a hole?
    Hi all,
    I have been learning metal machining now for a while and since getting my X2, I have been doing test machining on aluminium, plastic and wood. But one question bug me and that is tapping a hole for a screw. If I get a tapper (Is that how they call it?) and mount that on my X2, how does the tapping work? I can't imagine the tapped hole when the spindle is spinning so fast? How to retract the tapper?
    I hope you get my meaning on all this. Thanks.
    Alex
    Dec 2003
    To do rigid taping there are Canned programs that synchronize the Z to the spindle and prevent Feed o/r and spindle o/r, but you machine has to have this feature and option.
    It can be done however, if you have a spindle with rpm readout and use a floating tap holder, there is also a canned cycle suitable for floating tapping with the same constraints on the spindle and Z.
    Feb 2007
    Brunei
    Hi Al,
    Ok. So basically its not easy to do. I don't have spindle readout for my X2. Its quite a limited machine. How else can I do screw tapping if not with my X2? Can I manually tap it once the hole is drilled? Thanks.
    May 2007
    India
    Hi Alex,
    An floating attachment solves the problem. but it has constrains on your RPM.
    I am using the attachment for tapping - M16x1.5 for a depth of 12 mm.
    feed of tapp = pitch of thread.
    Try out & let me know ur results.
    Vishal
    Registered Mazaholic's Avatar
    May 2007
    This may be what your looking for.
    http://www.tapmatic.com/pdfs/TAPMATICGenCatManual.pdf
    They have many option for different machines.
    And yes you can tap it by hand with tapping fluid and a tap handle.
    Feb 2007
    Brunei
    Hi all,
    Thanks for the response. I think since I have very limited knowledge on tapping using the tapmatic, I will just resort to the traditional manual tapping as it can also be done. Thanks again for your help.
    1. tapered hole
      By dshowald in forum Milltronics
      Last Post: 05-01-2007, 12:19 PM
    2. How best to cut a hole in CNC.
      By cameraman32 in forum Benchtop Machines
      Last Post: 03-23-2007, 01:07 AM
    3. How do you drill a hole?
      By CuttersCov in forum General Metalwork Discussion
      Last Post: 02-28-2006, 08:33 AM
    4. finishing a hole
      By fastolds in forum GibbsCAM
      Last Post: 08-25-2005, 08:06 PM
    5. Need help with programming a hole
      By Hack in forum G-Code Programing
      Last Post: 07-23-2005, 11:08 PM
