Old 05-22-2007, 08:35 AM
Gold Member
InspirationTool is on a distinguished road
New tool chatters.... easy way to dull end mills?
I have an aluminum milling application where a new cobalt or carbide end mill chatters. After quite a few pieces (aluminum), the chatter fades. I assume this is due to the dulling of the edge and less "catching".
I'd like to get chatter free cuts from the beginning. Any ideas on how to dull the cutting flutes?
I am looking into getting some custom made neutral rake angle end mills made to help reduce this problem, as I suspect the long, thin, end mill is catching.
Thanks!
-Jeff
www.JeffAlbro.net/cnc/
Old 05-22-2007, 08:45 AM
Gold Member
Ken_Shea is on a distinguished road
Jeff,
What about just breaking the edge with one of those diamond pads like 3M makes or similiar.
Ken
Old 05-22-2007, 08:53 AM
Gold Member
Thanks Ken! I didn't know they existed. I'll look for them.
I also just realized, I could probably set something up with a granite surface plate, diamond dremel bit, and some gauge blocks. If I set the diamond surface a couple thousands over the center line I should have only a small amount of negative rake.
-Jeff
Old 05-22-2007, 09:39 AM
I have done it with very fine emery paper.Wrap it around a piece of wood and drag it gently down the cutting edge.
Old 05-22-2007, 12:24 PM
Gold Member
Ever have one of those "I'm a freakin IDIOT!" moments, and have that be a GOOD thing?
I had been chasing the chatter issue so intently, increasing feed and decreasing speed, that I hadn't been keeping an eye on my cut rate. My inch per tooth had gotten ridiculous.
So, it wasn't actually chatter, it was trying to force a long thin tool to take too much material off per tooth. Why that improved with a dull cutter, I'm not quite sure, but whatever.
But, I'm making parts again. I've got that "clouds of doom are finally parting" feeling.
Thanks everyone!
-Jeff
Old 05-23-2007, 09:15 PM
Lars is on a distinguished road
I always beat blast our new tools, we have WEDM so our beat blaster have very fine grid, it works like a charme.
Lars
Old 05-26-2007, 11:10 AM
thx1138 is on a distinguished road
If you got a tumbler, tumble them 1 at a time. how long depends on the media.
Old 05-27-2007, 03:29 AM
davereagan is on a distinguished road
Use G95 instead of G94 and you'll never lose track of your feed per tooth again.
Dave
How easy is it? SPD Employment Opportunity 26 03-03-2007 01:50 AM
Easy CNC and Easy Stepp'n kylecroft CNCzone Club House 5 02-18-2007 11:54 AM
Face Mills intstead of end mills balal General Metalwork Discussion 8 07-01-2006 12:35 AM
Pro Nc And Easy Dnc SMACUSTOMS General CNC (Mill and Lathe) Control Software (NC) 0 05-07-2006 05:08 PM
Please be easy, I'm new sin-city-custom General Metal Working Machines 4 03-01-2005 10:20 AM
