Old 05-20-2007, 07:54 PM
moreil is on a distinguished road
air cooling??
For a knee mill, milling mostly aluminium and steel, would air cooling be practical?
My object here is to avoid some of the hassles and mess involved in using coolant.
I'm thinking that blowing a stream of compressed air onto the part/tool might be an alternative? The air would drop sharply in temperature as it decompressed coming out of the nozzle, right?
Old 05-20-2007, 08:18 PM
marcel beaudry's Avatar
marcel beaudry is on a distinguished road
cold air
look at exxair products i have used exxair on several aluminium parts with good results even on steel parts.
Marcel Beaudry
Old 05-20-2007, 08:21 PM
moreil, That is generally referred to as "air blast cooling" or something similar. It's an acceptable method and is often applied to cutting where the material is not adhering to the cutter. Try doing a search on air blast and micro-drop or semi-dry coolant.
DZASTR
Old 07-01-2007, 06:09 AM
cnczoner is on a distinguished road
Not necessarily (dropping sharply in temperature). I am also looking into this as messy fluids are pretty much out for me right now, so I experimented with hand-blasting air from a small compressor I have, onto the bit, with a trigger-nozzle. As the air comes out of the nozzle, I expected it to be cooler than ambient, but it wasn't. My guess is that since it's freshly compressed, it's probably hotter than ambient in the tank, then the drop in temp brings it back to ambient-ish. I did not try, but should try, filling the tank, letting it cool, then seeing if it drops below ambient.
Also, blasting the ambient-temp air did very well for blowing chips around, but the bit heated up very quickly still.
Someone offered me a used portable A/C unit (for my garage) yesterday, and I'm now wondering if that could be used to cool the air blast too.
Cheers,
-Neil.
Old 07-01-2007, 08:45 AM
sailandoar's Avatar
sailandoar is on a distinguished road
Even if he cooling media (air) is warmer than ambient it is likely cooler than the the cutting tool and the cut zone. That is all you need. The rapid movement of the air facilitates transfer of thermal . All good stuff. You might consider adding a very small amount of moisture to the air. By using freshly compressed air in the summer time you are likely doing that already. The vaporisation of the moisture in the HOT cutting zone will further remove thermal energy. Another option is the little misting/fogging nozzles that that have flow rates as low as 0.004 gallon/minute. Water has a VERY high specific heat and it takes very little to cool a lot.
http://www.bete.com/
http://www.steinen.com/industrial/usa/english/index.php
http://www.cloudtops.com/fogging_system_parts.htm
Old 07-01-2007, 06:12 PM
ConKbot of Doom is on a distinguished road
At the last place I worked for, we milled material that we couldnt use coolant that would require cleaning.
We used a kool-mist sprayer fed with rubbing alcohol. On an open machine it would be fine, on an enclosed machine, you definitely dont want to be leaning in right after you open the door. I would be hesitant to use it on steel though, just because the risk of accidental ignition.
Cooling TMaster Xylotex 14 04-24-2006 05:12 PM
Cooling Fan Power Nono General Electronics Discussion 9 07-10-2005 10:08 AM
CPU Cooling Fan Wiring freak_brain General Electronics Discussion 5 07-07-2005 10:19 PM
Air Cooling? senor J. General Metal Working Machines 2 03-14-2005 08:05 PM
cooling alarants WoodWorking 8 09-21-2004 07:59 AM
