Old 04-05-2004, 09:24 PM
vacpress is on a distinguished road
imported rotary tables
Anyone know another source for this sort of rotary table?
this one is $100 from harborfreight. id imagine its imported:
http://www.harborfreight.com/cpi/cta...emnumber=47052
Design & Development
My Portfolio: www.robertguyser.com | CAD Blog I Contribute to: http://www.jeffcad.info
Old 04-05-2004, 09:36 PM
Gold Member
Ken_Shea is on a distinguished road
I do not see any means of locking the rotary table once it is set, you might ask about that if you decide to purchase.
Ken
Old 04-05-2004, 10:24 PM
Gold Member
lsfoils is on a distinguished road
Ken,
That brass colored knob is the table lock. Heres Grizzly's version:
oh, 109.00
http://www.grizzly.com/products/item...emnumber=H5685
Old 04-05-2004, 10:30 PM
Bloy2004's Avatar
Fumbling Machinist
Bloy2004 is on a distinguished road
Here's Lathemasters offering
http://www.lathemaster.com/ROTARYTABLESET.htm
Old 04-06-2004, 05:01 PM
i would be imediately turning this into a stepper driven axis. SO i dont think it needs a stop. I am mostly concerned about Slop and backlash. can backlash on a rotary axis be compensated for in software?
Old 04-06-2004, 06:08 PM
Bloy2004's Avatar
Fumbling Machinist
In Mach2 there is backlash compensation for axes...and i'm guessing that any controller software of worth has it also. I haven't looked deeply into any others as I have my hands full with Mach2.
Old 04-06-2004, 09:11 PM
Gold Member
This backlash compensation issue, how can software recognize backlash with out a direct mechanical consideration to recognize that the motor has moved and the table (or what ever) has not?
My CNC mill has software compensation built in also, but I am unable to mentally understand how it recognizes this backlash.
Ken
Old 04-06-2004, 09:56 PM
cbcnc is on a distinguished road
In TurboCnc it tells the motor to take so many steps (the value you have put in) everytime the motor changes direction. It assumes that this takes up the backlash before actually moving the fixture.
You have to measure the it while you are setting up the software.
Chris
Old 04-06-2004, 10:03 PM
Gold Member
Mystery solved,
thanks Chris.
Phasomatic to Rotary toolman General Electronics Discussion 4 03-20-2006 08:19 AM
Build a CNC rotary table? (longish) jcolley Mechanical Calculations/Engineering Design 0 02-12-2005 08:23 AM
Haas Rotary History ARB Haas Mills 4 01-13-2005 01:02 PM
rotary table chuck senor J. General Metalwork Discussion 2 12-15-2004 03:21 AM
Cross slide work pc on rotary table replicapro General Metalwork Discussion 4 07-08-2004 05:30 AM
