Old 05-17-2007, 04:19 PM
luismat is on a distinguished road
Please help, which Lathe+Mill should I buy
first of all, congratulations for a very active forum.
I'm a new member and I do appologize if this question has been asked/answered before.
I plan to build wood chess sets (eventually in the distant future some in Brass) , some Pen turning and some pipe work
my question is, and I've been searching the net, reading books and especially forums and I'm more confused than when I started
Which machines do you recommend for the above ?
1-Sherline CNC Lathe and CNC Mill
2-Sieg X1 or X2 (although I think its to big) + Sieg c1 lathe and then convert both to CNC
3-Taig (Peatol here in Europe) and convert to CNC
other ?
The parts are all around 2" diameter and max 5" in length..so quite small and most will be wood
I'm confused since every site I read says a different thing.
-Some say the sherline is too small and a toy, others say it is surprisingly efficient
-others defend Sieg, by price vs. performance
-others say nothing beats the Taig
Wood is soft to machine and the precision I require is not that high considering the objective...
I'm lost
Thanks in advance !!!
Old 05-18-2007, 08:32 AM
which machines
I understand this topic might be boring or recurrent... but due to my specific need, I would really appreciate any comments and opinions
regards
Old 05-24-2007, 08:14 AM
Which
no replies yet
Old 05-25-2007, 01:07 PM
fourperf is on a distinguished road
this is indeed a very informative active community. I think you should post in the mini lathe forum. You might have better luck there
Mark
Using your CNC Mill as a CNC Lathe lstool Knee Vertical Mills 10 08-02-2010 12:06 AM
Mill and lathe drafting101 Solidworks 4 05-16-2007 08:06 AM
lathe or mill niimush Mini Lathe 5 01-19-2007 04:14 PM
Using a Mill as a Lathe? Chris64 General Metalwork Discussion 20 10-07-2006 02:48 PM
Am I a mill or a lathe. Art Ransom Mach Mill 1 10-03-2006 08:08 AM
