Old 04-05-2004, 11:15 AM
barkster is on a distinguished road
Cutting Large Diameter Holes in Aluminum Plate
What is the best way to cut say a 3 or 4" hole in a 1/2" aluminum plate. I'd been using a jig saw but my lathe won't chuck the piece so I can't really clean it up. I have a Mini-mill but really don't know how to clean them up there either? Fly cutter? Never used on but thought that might be what I need? Thanks
Old 04-05-2004, 11:22 AM
Rekd's Avatar
Rekd is on a distinguished road
You should be able to cicular interpolate it using IJK or R values, depending on your controller. You could use a hole saw. You could use a fly cutter if it's adjustable.
There's several ways, and the best way will depend on your tooling, controller/machine etc.
'Rekd
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
Old 04-05-2004, 11:27 AM
My mill isn't cnc
Old 04-05-2004, 11:34 AM
Rekd's Avatar
DOH!
How close is the tolerance? You could scribe your circle and trace along it manually if it's not too critical. Or if you have a fly-cutter, the type with the cutter held in with set screws, you can approximate the dia and bore finish bore it with that. Or you could get a hole saw.
'Rekd
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
Old 04-05-2004, 11:40 AM
DR-Motion's Avatar
DR-Motion is on a distinguished road
A 3 or 4" hole... hmmm that's a pretty big hole to cut with a flycutter on a small machine. The best that I've managed are 1 1/4" holes x 1 1/2" deep using a boring head on my old chinese mini mill.
This was at the lowest speed setting and it still cause a bit of squeeling and low frequency rumple (not good because I was living in an hi-rise apartment at the time)
The problem is that a 3" hole has a circumference of almost 9 1/2" and at only 100 rpm spindle speed you end up with the cutting tool travelling at over 78 feet per minute.
This means that you have to take very light cuts because the cutting tool is held so far away from its rigid support.
Of course a cnc'd hole is relatively easy if you don't have too much backlash in your setup.
Good luck.
embrace enthusiasm to accomplish the task
Gary Davies... www.durhamrobotics.com
Old 04-05-2004, 11:47 AM
Looks like it may not be too much fun. I've used hole cutter for about 1.25" but never any larger. I'll figure something out. Thanks
Old 04-05-2004, 11:55 AM
Rekd's Avatar
Good luck. Let us know how it turns out.
'Rekd
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
Old 04-05-2004, 12:22 PM
pminmo's Avatar
pminmo is on a distinguished road
Do you have a router? If co use a carbide straight bit with a bearing and cut out a circle using particle board, masonite... as a template for a good finish.
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 04-05-2004, 12:50 PM
avsfan733 is on a distinguished road
rotary table?
Old 04-05-2004, 01:10 PM
Thats an good suggestion pminmo. Thanks
  #11   Ban this user!
Old 04-05-2004, 02:23 PM
oldguy is on a distinguished road
Believe it or not, use a good hole saw. With aluminium use a faster speed than you would for steel. Drill press (or mill) is best but a good angle 1/2 inch hand held drill will work. Clean chips frequently. Add some lube and have a good long handle to prevent winding up the hand held drill. I have cut large holes up to 4 inches in diameter in 1/2 steel and 1 inch aluminium as well as in stainless thinwall stainless steel with this method. Keeping chips cleared and tool cool is a must for tool life. An eye for perpendicular is also important when doing it hand-held to avoid catching on the cut through at the end of the cut. Of course a pilot hole for guidance is essential. Sometimes it is advisable to predrill a pilot hole and then to replace the hole saw's pilot drill bit with a piece of the same size drill rod notched to fit the locking set screw. The smooth drill rod won't enlarge the pilot hole as a drill bit may and keep the hole saw cutting trueer than would otherwise be the case, especially if you do not keep the process perpinduclar. Also, be sure to stop the saw from revolving before you remove it to clean chips. Then do not begin turning it until it is back in the cut. Do not rush it. Clean chipe often. But, do not be afraid to put some pressure on the down cut as a continuously cut chip is easier on the saw teeth than constantly wearing without really cutting, which builds up heat, but gets little progress. Remember, a lot of the heat is carried away with the chips, just like with a drill bit. The hole saw has more trouble clearing the chips, though. You hjave to help by stopping and removing them. Keep the saw cool. You will develope a feel for the right feed pressureis you have a mechanical affinity.
But, I have one more caution: Ease up on the downward pressure as you near the end of the cutting depth. It is also possible to turn the piece over to cut in from the opposite side, but I would advise against it. The two seldom align as well as a one-sided cut and cleanup is always needed. If extreem accuracy is not needed hand-held works well. Clean up can be accomplished with cartrige rolls, sanding sleeves or large cross pads (all are abrasive tools.) Of course if you have a mill or slow turning drill press you can use a fly cutter for clean-up. But, NEVER HAND HOLD A FLY CUTTRER! And they are for enlarging holes, not for making them. If you have a mill or drill press a hole cutter that uses a cutting tool similar to that in a fly cutter, but held at 90 degrees to the bar (parallel to the hole axis) will work if you are careful with the feed rate.
Good luck!
oldguy
  #12   Ban this user!
Old 04-05-2004, 02:26 PM
So you use a standard bi-metal hole saw to cut your aluminum, say from home depot?
Cutting fluid for aluminum? Ben General Metal Working Machines 7 11-17-2011 09:03 AM
cutting large arc's peterklos DIY-CNC Router Table Machines 13 04-24-2010 07:54 AM
Aluminum: flat, bar, sheet, plate, tooling plate?????????? Dan S DIY-CNC Router Table Machines 12 06-28-2007 12:48 AM
Having trouble cutting aluminum sheet fastturbovet General Metalwork Discussion 40 06-14-2005 10:33 PM
cutting Parts from a plate... need some tips Bird_E General Metalwork Discussion 2 04-09-2005 10:40 PM
