Old 04-05-2004, 10:45 AM
vacpress is on a distinguished road
60$ rotary table?
http://cgi.ebay.com/ws/eBayISAPI.dll...category=11809
wadda you guys think?
Design & Development
My Portfolio: www.robertguyser.com | CAD Blog I Contribute to: http://www.jeffcad.info
Old 04-05-2004, 11:18 AM
jimbo is on a distinguished road
dont buy it there. saw the same thing at surplus center. http://surpluscenter.com/item.asp?UI...tname=electric
I bought one off ebay for 30 before I saw the one at surplus center. the table itself is pretty nice though.
Old 04-05-2004, 12:32 PM
jimbo - do they work for rotary machining? how heavy duty is it?
could it be joints for a smallish robot arm? is it worth the $20 ?
backlash? speed? 4.5rpm?
could a bigger servo or a stepper be changed in?
how heavyduty does it seem?
Old 04-05-2004, 01:10 PM
I dont have access to it now, maybe in a week I could get some pics of it taken apart. I would say it is definitely worth the 20 maybe more. It is a nice piece of machining, all aluminum body and steel gears. I would like to know its original application, it is much more than a turntable.
I have not actually used it yet because my router is not done. But I did power it up on 12v, it was smooth, quiet and unstoppable. I could not feel any discernible backlash but I am sure there is some present with the gears. It is too slow as is. The motor/gearbox can be unbolted but I believe the pinion is pressed on the gearbox and the gearbox shaft was some odd size like 3/16".
At some point I would like to put adapt a servo to it and flush mount this permanently into the table of a moving gantry router.
They would probably be perfect for robot joints although I dont know how small is possible, or perhaps as the base of the arm. I hadnt thought of that. Maybe I should pick some extras. Only 2700 in stock.
It seems quite heavy duty and rigid, from memory it had a big sealed bearing like 4" ODx3"IDx.75" D that the table rotates on.
let me know if you would like the pics later.
Old 04-05-2004, 01:18 PM
also, only the center part rotates, it is like 3-4" dia, but with another plate bolted on it can be any size.
also surplus center says it has an encoder, it is not an encoder by normal terms. I believe it is just a tachometer or a 1ppr encoder. It does have a brake that can be tied to the motor supply to disable.
Old 04-05-2004, 01:36 PM
Bloy2004's Avatar
Fumbling Machinist
Bloy2004 is on a distinguished road
I believe that those devices were for turning those bigger dish antenna that used to be seen often in back yards... I was one of the guys that got one for the higher price...then as the order was shipped, discovered the better deal at Surplus....oh well.
Old 04-05-2004, 03:02 PM
boxwood is on a distinguished road
Yeah this guy used 2 of those hooked together to make a 5 axis router... very impressive
http://www.rainnea.com/cnc.htm
Learn from the mistakes of others you can't afford to make them all yourself!
Old 04-05-2004, 03:14 PM
boxwood - that rainnea machine uses these things?
i think im sold... i also like the idea that its got brakes... perfect for robot arms... assuming i can get those cliftons to interface the things...
i mean.. a $30. high powered servo driven rotary joint with a brake built in... just gotta get a real encoder on the thing.... i mean.. its practically a breakthrough... for me.. anyhow...
plus, that rainnea machine is very very amazing
Old 04-05-2004, 03:56 PM
the brake is on back of the globe motor so if you change to another servo you lose the brake.
I would also like to know if the rainnea machine really uses these units. They dont quite look the same.
Old 04-05-2004, 04:05 PM
teilhardo is on a distinguished road
I just bough one. I agree, for $30 it is well worth it. Even if one can't use it as a rotary table, the DC motor, gears and aluminum...all useful "junk" to have around the "shop"
-Tei
-Please check out my webiste-
http://www.teilhardo.com
  #11   Ban this user!
Old 04-05-2004, 04:12 PM
yeah - i just looked at the rainnea machine again. those look like asian import 4" rotary machining table. those are like $100 without a motor or anything.
  #12   Ban this user!
Old 04-06-2004, 02:10 AM
georgebarr is on a distinguished road
Does this item found at surpluscenter.com include the big rotary table and the motor? I can use this as a 4th axis for the lathe part of my mill.
Advise needed for rotary table conversion spoiledbrat DIY-CNC Router Table Machines 2 05-11-2005 02:34 PM
Build a CNC rotary table? (longish) jcolley Mechanical Calculations/Engineering Design 0 02-12-2005 08:23 AM
rotary table chuck senor J. General Metalwork Discussion 2 12-15-2004 03:21 AM
5th even 6th axis? how does it work ToMMY2ooo General Metal Working Machines 10 10-04-2004 03:58 PM
Cross slide work pc on rotary table replicapro General Metalwork Discussion 4 07-08-2004 05:30 AM
