Old 05-15-2007, 02:57 PM
boricuajdm is on a distinguished road
Mechanical Stop
We are a window and door manufacturer and we use our cnc to do all of our fabrication work for our doors such as drill and tapping the holes for a hinge. The problem we are having is that since the pieces are so long e.g. 72" or longer and our machine has about 28" of x axis travel we have to manually mark with a tape measure where we would like the fabrication done and line this up with a reference point on the machine.The problem is since there is a human factor involved not all the markings come out the same causing some fabrication to move 1/16"+-. I would like to know if anybody has had this sort of problem and if there is anykind of mechanical stop that you know of. Thanks
Old 05-15-2007, 03:50 PM
keebler303 is on a distinguished road
I would use a fence with flip up stops. You could have several for the different dimensions and flip down the one you need. Then all your holes will be on the money.
http://www.hartvilletool.com/product/11426
Matt
Mechanical Digitizing? DLMACHINE Digitizing and Laser Digitizing 25 07-08-2006 07:31 PM
Mechanical Stuff Nightz DIY-CNC Router Table Machines 0 11-07-2004 07:22 PM
mechanical questions... charleyy DIY-CNC Router Table Machines 13 08-22-2004 05:02 PM
