Old 05-14-2007, 07:33 AM
gcrandall is on a distinguished road
johnford 1120 vmc tool changer problem
I have a johnford vmc 1120 with an umbrella type tool changer. it hangs in the middle of a tool change, either when the carrosel comes over to grab the tool, in which case it doesn't know it's grabbed the tool so the tool number doesn't change, or after it grabs the tool and drops down, in which case the tool number changes. In either case the only way to clear it is to manually remove the tool and power down the machine.Any ideas where to look to fix this problem?Thanks
Bridgeport Interact 412 Tool Changer Problem RMARCH Bridgeport and Hardinge Mills 17 05-09-2011 10:57 AM
Matsuura MC-500V Tool Changer Problem nlh General Metal Working Machines 25 03-06-2011 04:50 PM
counter sensor problem on johnford vmc, need help wiredude CNC Machining Centers 0 05-10-2007 05:30 PM
Tool Changer Moondog Mach Software (ArtSoft software) 4 05-21-2006 02:34 PM
tool changer problem on haas mini mill Greg 24 Haas Mills 2 03-05-2006 02:20 PM
