Old 05-07-2007, 12:20 PM
petriej is on a distinguished road
Supermax -Y hard travel Help!!
I have a Supermax YCM-60 (with AB Bandit 4 controller) and it is acting up lately. I can be in the middle of running a program and the machine stops and displays the error message
"-Y hard travel". I have checked the soft travel limit switch and actually replaced the wiring in hopes that it was the problem. I have only been a machinist for three years and was trained in the military. My best guess right now is that the stepper motor is drawing too much amperage and the diagnostics of the machine are saying it is against a stop.
My other thought is that there may be an actual hard travel switch somewhere in the machine, but where - I don't see anything.
I have contacted YCI and they have not responded to my inquiries.
Any help would be appreciated.
Thank you.
Old 05-07-2007, 04:08 PM
springlakecnc is on a distinguished road
Hi, wouldn't the hard travel be a limit switch? If this happens when you are machining, is your tool bit squeeling or chattering? Even though you are no where near tripping the switch, sometimes, if a very low amp limit switch circuit is fed through a high amp limit switch contact, vibration, electrical noise, or most anything can interrupt the circuit. I have seen NEW machines do this. (no ones perfect) try jumpering the limit switch and if the problem goes away, BINGO! you need a new or lower amperage switch.
Old 05-07-2007, 04:23 PM
Limit Switch
Thank you for the re, but the problem doesn't seem to occur with chatter. It has acted up even when cutting polycarbonate or wood. I can move to the ends of the axis, and I get a soft travel fault - never a hard travel fault.
With soft travel, I can manually move the axis off of the limit with the handwheel. When I see a hard travel fault, the axis will not move and I have to shut the machine down.
Sometimes mulitple startups cannot get rid of the hard travel fault, and then my baby just sits there and can't do anything.
I can never duplicate the hard travel fault - even when I really hit the limit switches, it gives me soft travel. With this in mind, where does a hard travel fault come from?
Star SR20RII/Fanuc 18i, DMG CTX310V4/Fanuc 32i, DMG CTX310ECO/Siemens 8400, Mori NV5000/MAPS, Bridgeport 760/Fanuc 18i, Kiamaster 4NEII60/Fanuc 3t;Partmaker, Gibbscam
Yci Supermax krustykrab Hard and High Speed Machining 4 10-17-2011 08:56 PM
Need Supermax post Exodus8931 EdgeCam 10 10-30-2009 05:30 PM
SuperMax V105 Value coalstove General Metal Working Machines 0 10-12-2006 07:18 AM
yci supermax lathes mishikwest General Metal Working Machines 1 05-05-2006 08:08 PM
Yci Supermax Cnc Machine...got One? krustykrab General Metal Working Machines 11 01-30-2005 03:52 PM
