Old 04-29-2007, 07:50 AM
fizzman is on a distinguished road
How to move coordinate systems in Schaublin TMI-5
Hi.
Usually I use Emco machines, but now I've purchased a used Schaublin. In my Emco's i use the command "TRANS" to move coordinate systems. Is there some way to the same thing in my Schaublin to move for example the z-axis?
/Oskar
Old 05-01-2007, 12:06 PM
ConKbot of Doom is on a distinguished road
Does a G92 work for that? In our thermwood routers at work, we set the tools with a 5" block and use a G92 Z5.0 to set the Z coordinate. I'm not sure if a G92 has to do the other axes at the same time, or if it can only do one at a time, though.
Old 05-01-2007, 04:20 PM
Ok. Thanks. I'll try and see if it works for me. I'll post a reply of how it goes. Once again, thank you.
Old 05-07-2007, 04:13 AM
Still not working the way I want.
The G92 command only moves the machine cordinates. What I'm looking for is to move the coordinates in G54. This was not clear the first time I asked, sorry. I know how to move the coordinates of G53-G59 in the machine, but what I'm looking for is a way to move the coordinates in an ISO-program.
Any ideas?
Best regrds
/Oskar
Aaaargh! Using work coordinate systems with Centurion 6 Tarkus Milltronics 20 04-28-2007 09:43 PM
coordinate system kiethnt G-Code Programing 6 04-26-2007 07:46 AM
Using 3d Coordinate Conversion On A Vf4 renglish Haas Mills 3 02-02-2007 11:04 AM
Macro Work Coordinate firedog G-Code Programing 7 06-17-2005 12:03 PM
The X-Axles... to move or not to move! Wild4aces Mechanical Calculations/Engineering Design 1 03-18-2005 01:26 PM
