Old 03-30-2004, 03:27 PM
dpinson is on a distinguished road
Unhappy Mazak C axis programming
I just need an advice from a Mazak user concerning programming C axis in EIA mode. Usually, we use Mazatrol language with no problem but when I use MasterCAM to generate C-axis programming the C axis start jogging within the toolpath. As an example, I have join a sample file of 1 inche square on the face of a part. What is wrong with this program.
Old 07-02-2005, 03:06 PM
scalle is on a distinguished road
i can't directly see the problem in your program , but maybe you need to add the G17 code witch is used to select the working area ?
Mazak 8G M/C,mazatrol eia-t, z axis stuck imwllc Mazak, Mitsubishi, Mazatrol 7 09-07-2009 10:48 AM
CNC Glossary CNCadmin CNCzone Club House 17 03-09-2008 03:08 PM
4020 4th axis problems little bubba Fadal 3 06-13-2005 09:08 PM
4th axis programming smoggy General CNC (Mill and Lathe) Control Software (NC) 2 05-18-2005 11:16 AM
4 and 5 axis programming Cammotion G-Code Programing 1 03-02-2005 11:39 PM
