Old 04-22-2007, 02:24 PM
andy55 is on a distinguished road
12x24 lathe conversion examples?
Hi all,
We've been looking at an Opti D320x630 lathe (http://www.optimum-maschinen.de/prod...320/index.html) with my friend. We've already converted a mill to cnc but would like to do this lathe next.
Anyone know some good links or threads where converting this size of lathe is discussed ?
From the experience with the mill we are going to go with ballscrews and servos right away (no more acme-threads and steppers please...)
It looks like the leadscrew that is used for threading when the machine is used in manual mode can be removed and replaced with a ballscrew. There seems to be lots of room behind the handwheels for mounting the ballnut, and the motor could be mounted in the tailstock end.
I'm more worried about the X-movement, and would be very interested if someone had already done a conversion so I could see if/how a ballscrew fits the standard dovetail+slide. mounting the motor behind the lathe out of the operators way seems to be a good idea.
thanks for any replies,
AW
Old 04-23-2007, 09:52 AM
BobWarfield's Avatar
BobWarfield is on a distinguished road
Track down Ron111's conversions.
You will likely want to mount the ballscrew alongside the slide rather than inside the dovetail area as there is a lot more room that way. That's how Ron111 did his last conversion.
Best,
BW
Old 04-23-2007, 10:23 AM
thanks, I think I found it:
http://www.cnczone.com/forums/showthread.php?t=32470
further examples amr_elsayed CamWorks 2 04-10-2007 11:05 AM
Need Examples... Plz help Israa G-Code Programing 13 02-10-2007 04:56 PM
Wiring help for CNC Lathe conversion pbreed Vertical Mill, Lathe Project Log 1 12-04-2005 08:42 PM
New CNC lathe conversion plans CNCadmin General Metal Working Machines 10 03-06-2005 11:20 PM
CNC lathe conversion (again, sorry!) kong General Metal Working Machines 8 03-27-2004 01:06 PM
