Old 03-29-2004, 08:48 PM
Fudd is on a distinguished road
Home built barfeeder
Does anyone have or know of plans for a home built barfeeder for a CNC lathe? I have a YAM CK-1 Chucker.
Thanks,
Scott
Old 01-28-2008, 02:41 AM
Ztiggi is on a distinguished road
taking up an old thread here....
i am also thinking about this,
what i was thinking about was a pneumatic cylinder that pushes the bar,
and use the turret to stop the movement in correct position.
i could use a thrust bearing on the cylinder and make it push all the time,
then maybe a long spring may do the job as well.
but the best would be to use a solenoid activated by M-code,
does anybody know if that's possible?
can i get a signal anywhere activated by an M-code?
Old 01-28-2008, 08:50 AM
Have a look in this Thread; I posted a couple of long descriptions with some pictures.
http://www.cnczone.com/forums/showthread.php?p=338094
Also this Thread about the user M functions, and the Thread I link from this one.
http://www.cnczone.com/forums/showthread.php?t=50357
EDIT: The details about the user M are for Haas of course but the principles are the same on most machines.
Home Built Tubing Bender ccm Bending, Forging,Extrusion... 46 05-15-2008 05:30 PM
Another home built router :) steveald DIY-CNC Router Table Machines 69 03-19-2005 12:22 PM
Home Built Router/Drag Diamond Engraver DaSigntist DIY-CNC Router Table Machines 49 01-24-2005 01:02 AM
4-5 axis control recomendations for home built horizontal machine Kmed General CNC (Mill and Lathe) Control Software (NC) 3 01-17-2005 04:04 PM
Home built controller Stephen General Electronics Discussion 1 09-22-2004 11:02 PM
