Results 1 to 9 of 9
Thread: Crashed my lathe, now tool is above center
    May 2005
    I crashed the turret into the spindle (Don't ask). Now the tool is above center. How do I get to the taper pins or whatever locks the turret in position? It's an Ikegai FT20U. There are 4 plugs around the turret that look like access holes.
    Jul 2006
    not sure on that particular machine, but on our machines you
    pull them out with a slide hammer, indicate the turret back in
    ream the holes lightly by hand, then replace.
    i havn't had to do this for 8 years thank goodness.
    Jun 2005
    us
    Your turret rotated a little .If your lathe does not have turret pins in it.There is 6 to 8 bolts that hold the turret disc on losen them and indicate the turret back in .
    If this does have turret pins in it .Take the turret disk off
    take the taper pins out there bent file down the burs on the holes the pins were in. Put the turret disc back on make sure you but it back in the same place
    so the tool numbers are right. Then put a boring bar holder in it an indicate it in and tighten the turret bolts . Now this will cause some disagreement i sugest leave the pins OUT
    I my opinon the pins don't help much to keep the turret from rotating . But when there crashed the pins are bent and the holes there in are all messed up. Alot of lathes are shipped without the pins because they are problems after a crash. I have never known of a turret to rotate during cutting without the pins the 8 bolts that hold the turret on will do the job. Also its alot easyer
    to aline a turret without pins after a crash .
    If you want to but them back in you must get two new taper pins and the holes must be re reamed with a reamer that maches the taper pins do this after the turret is alined .
    Tim
    May 2006
    Sweden
    I have removed thoose pins years ago, they only makes alot of probs.. My turret doesnt move during operation, so go with the post above....
    May 2005
    How do you get to the bolts? The turret has a large nut in the center. I removed that nut and pulled out the key. The turret seems to be pressed onto the shaft or just stuck. I didn't get much time to try and get it off and I didn't know if it had to come off or not. I can see what looks like some pins thru those 4 plugs I was talking about, but they don't look like the index into the turret when it clamps. Maybe somebody already took them out and replaced them with shorter pins. Any suggestions?
    Jul 2006
    I worked for a company that had a lot of inexperienced personell, they
    crashed a lot.
    We ran a couple of machines with the taper pins removed while waiting
    on shipping. no problems.
    do you have a digital camera? a pic would be sweeeeeet.
    BE NICE!!!!!
    da riverrat
    May 2005
    I'll post a pic when I get home tomorrow.
    May 2006
    Sweden
    There usually are a circle of bolts on a big pitch dia, loosen those and thighten one or two a bit, then you can adjust the turret against the "locking gear".. ( Just reposition the turret with a plastic hammer and thighten the bolts, without the taper pins the turret prob. moves a bit while thightening the bolts,just compensate for this while adjusting it) Never heard of loosing the centerbolt unless the turret are to be removed.
    May 2005
    Here's a link to my myspace album. I left the puller on there so maybe if it was under constant pressure it would pop loose during the night or something.
    http://viewmorepics.myspace.com/inde...albumId=476692
    1. puma 8hc turning center tool changer
      By fritos in forum Daewoo/Doosan
      Last Post: 03-16-2011, 03:33 AM
    2. Using lathe center
      By linesman 71 in forum G-Code Programing
      Last Post: 03-24-2007, 04:49 AM
    3. tool center or edge?
      By spock in forum BobCad-Cam
      Last Post: 02-05-2007, 01:45 AM
    4. Does V20 program tool tip or tool center
      By Pat in forum BobCad-Cam
      Last Post: 06-17-2005, 06:46 PM
    5. CNC Lathe&Machining Center which ones to get?
      By kanankeban in forum General Metal Working Machines
      Last Post: 06-16-2005, 05:04 PM
