Old 04-22-2007, 08:18 AM
REVCAM_Bob is on a distinguished road
Probe and toolsetter suggestions?
I am considering adding a probe and a tool setter to a Fadal with the
Fanuc 18i control. I don't know much about probes or tool setters.
Can you guys offer any suggestions? Is there any brand that is better suited
to the control I am useing?
Thanks!
Old 04-22-2007, 08:23 AM
More probe tool setter questions...
Also, how much should I expect to have to shell out for a probe? A tool setter?
By the way I do NOT need submicron accuracy... any thing in the 0.0001 or 0.0002" would probably work....
Old 04-22-2007, 02:55 PM
R1_pilot is on a distinguished road
I am not sure what your budget is. But I have been using Renishaw's TS27R touch probe with great results. I have two, one in a Kitamura and one in a Mazak and I am getting another one for a new Kitamura we just installed. The new one is wireless as the machine is a vertical with two pallets.
I also have the NC1 (lase type) in a Kytamura horizontal, excellent too but it will not compensate for diameter.
Cost for the TS27 is 8-10k approx.
J
Old 04-22-2007, 03:27 PM
Al_The_Man's Avatar
If you want a very high precision 3 axis probe look at the Heidenhain KT130.
about $750 last time I checked.
Old 04-22-2007, 03:38 PM
Why would a probe be $750 and the tool setter be 8-10K??
Old 04-22-2007, 04:23 PM
Al_The_Man's Avatar
Renishaw is very high priced to begin with, also you are paying for features like infra red/wire-less transmission, and you are getting the probe routines, which you would have to write yourself, with a self-engineered system.
Old 04-22-2007, 04:29 PM
infra red??
I started a query in the electronics section regarding the infra red thing...
Readers are only $15, don't know about sending...
Here is a thought: Use a cheap (or expensive i.e <$100) electronic edge
finder with the red led's, and use a sensor to detect the LED's....
The same concept could be used for the tool setting thing...
Any thoughts? i.e. how to detect if the led is on or not?
This just seems like 8-10K is a Smoking Crack price and someone should
do something about it....
Old 04-22-2007, 07:17 PM
big_mak is on a distinguished road
Al,
Is that Heidenhain just simply a touch probe? Or is it a system with macros and such?
I've used Reinishaw NC1 Laser for tool setting, and it will pick up diameter depending on the macros you are running, it will even sheck form tools from what I remember.
I have a haas, and I bought the probing option tc27 and touch probe, and all the macros was $4995 with the machine. Smoking deal from what I can see here. I think the NC1 that I was using was about $8000 canadian. With out installation. we had a bit of troubleshooting to do with it, as the Renishaw macros weren't 100% out of the box compatible with the Matsuura and Fanuc 16i
Any questions you can PM me.
"It's only funny until some one get's hurt, and then it's just hilarious!!" Mike Patton - Faith No More Ricochet
Old 04-22-2007, 07:25 PM
Al_The_Man's Avatar
The heidenhain does not include macros, if you have the Renishaw, they should be adaptable, otherwise it is write your own.
Old 04-22-2007, 11:00 PM
With this heidenhain, does it have a receiver, or a cable that lets the machine know that there has been a trigger, or is it simply an audible signal for the operator to hit origin?
Nikken probes worked this way for the Matsuura's that I ran until we got the renishaw systems. I can't believe that there would be $7000 difference between 2 very similar products. Just want to make sure we are comparing apples to apples here.
  #11   Ban this user!
Old 04-22-2007, 11:21 PM
MDLang is on a distinguished road
There is no way the comparison here is apples to apples. I'd suggest more like apples to prunes.
I can get a "probe" for 75.00 dollars and a "touch setter" for another 75.00 But it's hardly a deal.
I would suggest there is a good reason that renishaw is very popular despite the seemingly high price.
I find the renishaw probes as well as the anvil, plunger and laser touch setters very reliable, robust and accurate. They are proven, well supported and work every day.
If you can't afford them you probably don't need them. If you can afford them the only real competition is likely as expensive.
Choose otherwise at your own risk.
Mike
  #12   Ban this user!
Old 04-30-2007, 07:23 AM
wewon is on a distinguished road
Funny that I found this thread.
I work for a research company and we are about to install a BLUM TC50 onto a test machine as well as a Renishaw later. The BLUM model is roughly $9K, I will try to get you more information about the performance later.
Busted Probe.... zedzero Haas Mills 1 04-23-2007 07:19 AM
Mazak / Yasnak MX3 control toolsetter soszi1950 Mazak, Mitsubishi, Mazatrol 1 02-10-2007 08:24 AM
CMM probe sab Open Source Controller Boards 3 03-07-2006 04:37 AM
Probe Cost jhwatts Digitizing and Laser Digitizing 17 01-19-2006 11:08 PM
Building a probe itsme Digitizing and Laser Digitizing 19 10-01-2005 11:56 AM
