Old 04-18-2007, 04:44 PM
a_davies616@hot is on a distinguished road
A2100 control touch screen problems!
Have just purchased a 1998 Cincinatti Milacron Dart 750 machining centre with an A2100 control. Machine in very good condition for it's age especially the control panel which looks like new i.e. keys not worn or dirty. Machine started up for the first time and it seems the reason for this is that the touch screen and control panel have been disabled (probably to stop untrained operators changing programs) and that all the programming on this machine has been done through a network.
First two questions; Can the screen and panel be disabled in this way and how do I change this. Machine works fine with keyboard and mouse plugged into the back, but this is not very practical.
Next problem I have, the machine came with no programming or operating manuals (the risk you take buying a machine at auction) does anyone know where I can obtain these.
If anyone would like to contact me I can forward any additional information if needed.
Any help would be very much appreciated.
Old 04-19-2007, 12:44 PM
cncatj is on a distinguished road
check if the touch screen is pluged by removing the back cover in the op. panel also you will find a pcb that conects to that touch screen if it is conected check at initial diagnostic screen probably it is not "passing"
wich would mean you have to replace the whole assembly they do not sell you the touch screen only 2 years ago i did replaced a touch screen in one of our machines it cost around 3,000 us dlls with Siemens usa
also they have the manuals that you need!
Do you know the basics of the machine?
Homemade Screen Printer/Silk Screen Sbthomas13 Machine Created Art 20 02-13-2009 06:35 PM
Acramatic 2100/Cincinnati Lancer - Touch screen problem! Per O. Machine Problems, Solutions , Wireless DNC, serial port 10 02-08-2009 04:19 PM
Anyone Having Problems Getting in touch with CNC bridges/Harlow Ind.?? TheWolf Benchtop Machines 9 02-04-2007 08:39 AM
Problems with TNC 155 Heidenhan Screen Jungle Jim Bridgeport and Hardinge Mills 1 12-02-2006 05:21 AM
anyone use a touch screen? jderou Screen Layouts, Post Processors & Misc 13 09-01-2005 06:09 PM
