Old 03-27-2004, 05:35 PM
cnczoner is on a distinguished road
Easy CNC conversion
Just joined this list, and intend to purchase a mini-lathe, which will eventually be CNC'ed.
Other than Sherline, which has a bolt-on kit to mount stepper motors on their mini-lathe, are there any other bolt-on kits (or simple conversions) for adding stepper motors to the other popular mini-lathes (HF, Homier, Grizzly, LatheMaster, etc)?
Or is the custom bracketry simple to make?
Thanks,
-Neil.
Old 03-27-2004, 08:39 PM
Urgundiz is on a distinguished road
You can attach the steppers to the axis in really easy ways. You can find photos in the forum of people that has attached their steppers to the machine it with 4 bolts for clearance, an Alu plate, two inches of reinforced hose and two clamps, and they say it's working with no problem and good results. And the aestethics aren't so bad
For example, take a look at the photo. Do not know (I can't see it) if the owner used reinforced hose, but the bolt&plate mounting is easy and effective.
Hope it helps
/U
Old 03-28-2004, 10:01 AM
Bloy2004's Avatar
Fumbling Machinist
Bloy2004 is on a distinguished road
so similar! and both are so cute....as Huffed so stated. I just had to put this here...as I like these machines for intricate pieces of smaller dimension.
Name:	lcv-i bilder ebay 6.jpg‎
Old 03-28-2004, 11:11 PM
Okay, you make it sound easy. So I went down to my local HF today and looked at the 7x10 lathe. The handwheel for the cross-slide was missing, so it was easy to see how I could add a plate to mount a stepper, and it actually seems very simple. I'm over-analyzing and agonizing over it for nothing.
Thanks,
-Neil.
Manual lathe CNC conversion kong General Metal Working Machines 10 08-20-2005 03:56 PM
Pics of my RF45 clone cnc conversion with flood coolant CNCPlastic Knee Vertical Mills 9 01-26-2005 02:02 PM
Gorton P1-2 + Sherline CNC mill conversion. jaydee116 Vertical Mill, Lathe Project Log 2 12-11-2004 11:10 PM
First Impressions for CNC mini mill conversion CNCadmin General Metal Working Machines 4 11-16-2004 08:37 PM
possible cnc conversion on homier mini mill WsW-WYATT Benchtop Machines 3 03-27-2004 07:24 AM
