Old 04-06-2007, 01:01 AM
Jedi is on a distinguished road
Vibration turning between centers
Im having a hard time turning the OD of a 35" length stainless steel bar 2.5" in diameter. Ive adjusted the speeds from 300-1200 as well as slow feeds and fast feeds. Ive found that a slow speed of 400 and a fast feed help as well as a smaller nose radius insert with a positive rake. Any other tips would be great. Thanks
Old 04-06-2007, 11:07 AM
JH-Q is on a distinguished road
Any chances of using a steady or following rest?
Seems like you have all the tricks tested which come in to my mind.
Old 04-06-2007, 11:40 AM
Have you tried the on-edge high positive inserts like Hertel? J&L used to have them in their catalog, Kennametal owns Hertel. You might have to look in the Kennametal turning tool catalog or call them.
add note: They use the name Fix-Perfect
DZASTR
Old 04-08-2007, 12:26 PM
Im using a high positive stainless insert. If i use the steady rest will it push the work off centre because i still have to turn the piece around and machine the other side?
Monarch machining centers HuFlungDung General Metal Working Machines 15 02-23-2009 09:57 PM
Vibration reduction.. JerryFlyGuy Mechanical Calculations/Engineering Design 34 11-09-2008 08:33 AM
Extreme Vibration with FNC 1ctoolfool Haas Mills 2 12-04-2006 09:37 PM
Vibration IS your enemy! Bubba Benchtop Machines 1 10-06-2005 08:44 PM
wondering about vibration marx911 80/20, TSLOTS and other Aluminum Framing Systems 7 05-23-2005 11:58 PM
