Old 03-28-2007, 03:45 PM
buckie555 is on a distinguished road
Affordable Spindle With ATC
Can anybody recommend a supplier/part no for a spindle with the following specs:
30 or 40 taper
at least 6000rpm preferably 10,000rpm
support for automatic toolchange i.e. gripper drawbar with air cylinder ram
brand new or refurb
5-10hp.
Either motorised direct drive or belt drive
And here's the catch - for less than $3500.
Is this possible at this price point. The Elte spindles from Italy look reasonably attractive although they're really designed for wood and I'm looking for something that is more suited to metalworking.
It's for fitting to a custom cnc mill so fittings and dimensions are not a problem. Up until now I've been using an old Int 30 Bridgeport spindle which is very much overdue for retirement.
Any suggestions and first hand experience are welcome.
Thanks,
Neil
Old 03-28-2007, 05:52 PM
Zumba is on a distinguished road
D N E
Old 03-28-2007, 06:07 PM
ben_heinman is on a distinguished road
Auction
You might want to try going to a public auction to see what you can pick up. You might be able to find a machine with a good spindle/atc. You'll have to do some digging, they have them quite often it's just you don't hear about them much.
affordable 3 axes CNC router ice Product Announcements & Manufacturer News 0 01-08-2007 12:58 AM
Where to find an affordable BTR? Haaatschi Fanuc 1 03-17-2006 08:21 PM
Still looking for affordable Engraving system? pro-soft Mechanical Calculations/Engineering Design 2 11-14-2005 06:44 AM
affordable wet saw? darth442 80/20, TSLOTS and other Aluminum Framing Systems 3 07-24-2005 12:39 PM
