Old 03-26-2007, 07:09 PM
widgitmaster's Avatar
Gold Member
widgitmaster is on a distinguished road
Need info on Cutting oils
I have been using synthetic water soluable coolant in my new lathe for several months now, and everything is rusting so quickly I can't stand it!
I live in Florida which is high humidity, and my shop is in my garage with the door open frequently.
What I would like to do is remove the coolant and replace it with cutting oil, but brown chlorene based sulpher oil for threading is expensive!
Does anyone know of a brand of clear cutting oil the is not so expensive?
Thanks,
Eric
Old 03-26-2007, 09:04 PM
Chuck Reamer's Avatar
Chuck Reamer is on a distinguished road
What kind of coolant have you been using? and at what concentration?
I would think that straight cutting oil would be a hell of a mess to work with all the time, and very expensive like you say. I have never seen a cheap enough cutting oil, not cheap enough to use a huge amount of.
Try to speak with a Tech Rep from your coolant manufacturer to see what they suggest.
I run dry on both my manual lathes at work and dont have any problems. I use a cutting oil for drilling and threading, but just run dry all of the time. A little lube on the ways and its usually as good as gold.
Live free or die
Old 03-26-2007, 09:35 PM
miljnor's Avatar
S.N.A.F.U.
miljnor is on a distinguished road
Cnc and manual machines are different beasts!
You can't use one methodology on both types.
If your using synthetic water soluble I will assume your a CNC person if not then ignore my post.
I have used many coolants synthetic and otherwise.
out of all of them I have switched to Blaser lube. It mixes 10/1 water/oil and generally wont go bad if kept at these solution levels.
It is some form of vegetable oil base, so if your green conscience, then its a good one for you.
Of course if you eat or drink it, expect to die in short order and plan accordingly.
Most of the time when your machine is running low you need more coolant because the water evaporated and you can get away with a 1% add in solution. thus making it last alot longer.
thanks
Michael T.
"If you don't stand for something, chances are, you'll fall for anything!"
Old 03-26-2007, 09:58 PM
Gold Member
I should have been more specific, as I am running a 13x40 engine lathe.
I have a productive hobby shop, and machine a wide range of materials.
Trying to turn 303-SS or tool steel dry is hell on tooling, and generates a lot of heat. Turning MIC-6 aluminum can not be turned dry if you want to do more than one part! I have a 10 gallon sump with synthetic coolant mixed at 4oz/gallon
ID:	34325   Click image for larger version
Old 03-26-2007, 10:09 PM
Originally Posted by widgitmaster View Post
....synthetic coolant mixed at 4oz/gallon
Have you tried increasing the coolant concentration? I have found that going higher than the suppliers recommendation is sometimes necessary to stop rust. I think the concentration needs to be high enough to leave a thin, but not too thin, film of coolant on the machine surfaces when the water evaporates away.
Old 03-26-2007, 10:13 PM
Gold Member
Thanks Geof, I'll try that first!
Eric
Old 03-26-2007, 11:58 PM
davereagan is on a distinguished road
Concentration
4 ounces per gallon is 32:1, which is an extremely low concentration for any kind of coolant, even when only rust inhibition is desired, asin grinding. I would try 10 ounces per gallon and see what happens. If the lubricity is good enough, synthetics seem to last forever, but I've never had success tapping with them.
Dave
Old 03-27-2007, 12:44 AM
in2steam is on a distinguished road
Another thing you may want to try is on areas which are exposed but not always used, is spray some LPS 3 on. That forms a nice waxy barrier that keeps the cutting fluid out of, its esp nice on mills were the bed is not used alot, but works well on those lathe spots that don't see often use.
chris
Old 03-27-2007, 02:29 PM
Eric, Have you had your water tested? Might be a problem. Your coolant supplier should be able to test it for you. Many suppliers have specific formulations for given water conditions. Generally they are no more expensive, just variations in the mixtures. If the water is the problem, you are not alone in your local with this problem.
DZASTR
Old 03-27-2007, 09:14 PM
miljnor's Avatar
S.N.A.F.U.
They put so much chlorine in our water I had to go to di-water.
Wouldn't be surprised if it is your water..
Good call on that one.
thanks
Michael T.
  #11   Ban this user!
Old 03-27-2007, 09:41 PM
9566317 is on a distinguished road
Smile Coolants are trouble
I have a lot of equipment in my shop. Centerless grinders, 30 cnc machines,
Custom machining area and I think I run about every type of material out there. Permenant molded aluminum, Stainless \. Steels and cast irons.
I also think in the past 15 tears I have tried about every coolant and type out there. Full syntetics are hard on equipment as the lubricity packages in them are poor and tend to "gum up" measuring tools and eat rubber seals.Purpose of syntetics was to eleminate anirobc bacteria's that live on oils and gives you the nice Monday Morning rotten egg smell.Semi senthetics have a high oil package in the but because of the oils in it cause the stink.
I have been using a Houghton semi syntetic for 3 years now that was developed by Houghton and Boeing.I believe it is a Houghton 954. I use it at differant conentrations on differant machines.Cast iron and steel at 5 -7 %
Aluminum around 15 % Grinders at 2 % I have never had a Bacterial issue or stink and am happy with it. I do HAve poor water with High clorine levels.
In machines that sit for more than a week I have put a fish tank air pump on the machines just to bubble away in the coolant tank to keep the surfaces broken up and help keep the coolant fresh.Also put a oil skimmer on your tank as this will extend the life of your tank and will be nicer to work in.I also had a big drop in dermatitis in my employee's after changing to Houghtons product.
Hope this helps
Old 03-27-2007, 11:24 PM
miljnor's Avatar
S.N.A.F.U.
Hope this helps
I have all these positive effects with Blaser oils as well.
thanks
Michael T.
Need Laser Cutting Machine info, URGENT!! masterblaster11 Laser Engraving & Cutting Machines 4 03-23-2006 12:57 AM
oils for Cincom F12 emilm General Metal Working Machines 1 09-27-2005 05:40 PM
info on cutting rc parts landart DIY-CNC Router Table Machines 0 01-18-2004 06:29 AM
