Old 03-26-2007, 02:33 AM
hotponyshoes is on a distinguished road
Has anybody ever met 'The Denbigh' Milling machine?
I am currently trying to find a manual for 'The Denbigh' C.V.S. Milling machine.
I am having the following problems..
I can't seem to adjust the tension of the motor drive belt - it looks like the whole assembley rotates and is held in place by one bolt. The bolt moves but the motor does not. Would a belt dressing on the leather belt prevent slip?
The lathes.co.uk indicates that the table has power feed in both directions. Mine only seems to have 4 speed powerfeed in one direction.
Also, the powerfeed seems to 'slip' - it can be engaged but if you hold the table handle it just stops the drive shaft turning.
Thanks!
Rotwerk EFM 200 DS Milling Machine Shanghyd General Metal Working Machines 0 10-13-2006 06:16 AM
need help with tos milling machine derkiow General Metal Working Machines 0 03-08-2006 08:06 AM
Why would this machine be bad for milling? jevs Knee Vertical Mills 5 06-16-2005 10:49 PM
D&M Milling machine mrand Benchtop Machines 1 03-11-2005 02:58 AM
which milling machine to start out with? cowanrg Benchtop Machines 7 01-18-2005 04:34 PM
