Old 03-25-2007, 11:26 AM
CoolhandLuke is on a distinguished road
Drilling a .010 hole
I need to drill a .010 hole about .060 deep...I need a short drill so there more rigidity. I am making sight pins for archery sights.
Old 03-25-2007, 11:50 AM
I don't know how many you need, but you might be better off having them "drilled" on an EDM machine.
DZASTR
Old 03-25-2007, 05:10 PM
Stepper Monkey is on a distinguished road
This may not work for your application, but if I need a whole bunch of holes in a line the way I think you do for the sight pins, I am lazy and usually cheat by milling or engraving half-round grooves in two separate pieces and bolting them together.
Last used that on a fuel atomiser, as I didn't fancy drilling dozens of .012 holes .500 deep!
Old 03-25-2007, 06:55 PM
This is what I am making
Old 03-25-2007, 07:40 PM
Pres is on a distinguished road
One picture is worth a thousand words!
So is the 0.010" hole you need the main hole that the lens fits in? or ??
Old 03-25-2007, 10:05 PM
I am making the pin, here is a pic of just the pin
Old 03-25-2007, 10:06 PM
Click on the image so you can see it.
Old 03-25-2007, 10:44 PM
HuFlungDung's Avatar
Moderator
I bought a few .010" drills lately from Travers Tool. They had a pretty good selection, the shank is 1mm, I believe, and the flute length is reasonably short and stiff. I managed to drill without a starter spot....didn't think I had anything that would make a good starter dimple for it anyways.
Oh, I used a spindle speeder to run it at 15,000 rpm. I went real real slow on the feed.....about .5 ipm in 303 stainless......I did not want to spoil the job. I managed to drill about 30 holes per drill, only penetrating about .015 material thickness.
Postprocessor code always drilling same hole twice Maurice Proulx SprutCAM 2 12-07-2006 09:03 PM
Homebuilt CNC Hole Drilling Machine nitrosaturn DIY-CNC Router Table Machines 8 11-14-2006 02:44 AM
Drilling a hole in a 3D model mayhugh1 SprutCAM 5 10-25-2006 11:51 AM
Accurate Hole Layout & Drilling vacpress Mechanical Calculations/Engineering Design 11 04-19-2006 12:21 PM
Deep hole drilling on OKK eddie G-Code Programing 1 09-21-2005 06:55 PM
