Old 03-19-2004, 11:09 PM
*Registered*
Noah is on a distinguished road
So I got this new cool ballscrew...
I am quite a geek when it comes to mechanical gadgets like these you see and I soon as my new ballscrew arrived I quickly ripped apart the packaging on the ballscrew and attempted to thread on a ballnut. Being in such haste I did not realize that the cardboard tube inserted in the nut must be there for a reason. So as you can imagine. Little steel 3/32" balls ended up everywhere. After spending half an hour picking them all back up I now wonder how to put them back in the nut. The other 3 nuts gave me no problem now that I have learned my lesson, but I hope this lesson does not involve buying a new nut, does it? Is there any way to save my poor ballnut?
Old 03-19-2004, 11:17 PM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
Been there done that, it took some patence but I got mine back together.
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 03-19-2004, 11:19 PM
*Registered*
Err yeah, but how? Do you just keep putting balls in the nut. But wait, wouldn't they just fall out at the top of the nut?
Old 03-19-2004, 11:23 PM
deanc500 is on a distinguished road
You should be able to replace the balls. One method is as follows:
Remove the recirculating guide tube thing (whatever its called). Place the empty nut on the screw. Feed balls down one side until they go all the way through and start coming out the exit point. Place a small dab of thick grease in one end of the guide tube. Load the other end of the tube with the remainder of the balls and hold them in with more grease. With the grease holding the balls in the tube, you will be able to re attach it to the nut without them falling out.
Dean
Old 03-19-2004, 11:25 PM
*Registered*
Thanks, I had not thought of that.
Old 03-20-2004, 03:50 AM
svenakela is on a distinguished road
There are some informative howto's at http://www.industrialhobbies.com that should help you out.
Regards,
Sven
Ballscrew Basics Swede Linear and Rotary Motion 101 04-16-2012 08:09 PM
Ballscrew advise... Dave's_Not_Here Linear and Rotary Motion 10 06-14-2005 11:21 PM
Super simple preloaded ballscrew design - It Works! jimjovan Vertical Mill, Lathe Project Log 9 04-25-2005 11:02 AM
Ground Ballscrew - No nut! Swede General Metal Working Machines 4 11-20-2004 02:42 PM
ballscrew repair and some general questions jimbo DIY-CNC Router Table Machines 11 09-27-2003 03:48 PM
