Old 03-22-2007, 01:08 AM
Jay Rad is on a distinguished road
HELP! Mitsubishi cnc hobb problem
Please help!
Has anyone worked with a mits hobbing machine before? We have a 5 axis model gd20cnc mach. that is leaking hyd. fluid from bad o-rings on the work table into the way lube tank. We need to remove the work table assembly and are half way there right now, but dont know how to get the shaft out.
Please help us!!!!!
CH-VMC 500-Mitsubishi 60S thanhct CNC Machining Centers 5 04-02-2007 02:49 AM
Posprocessador Mitsubishi Vinicius Mazak, Mitsubishi, Mazatrol 1 02-27-2007 03:07 PM
Mitsubishi H110 Wedm Wire Problem osomaker CNC Plasma and Waterjet Machines 1 12-11-2006 12:23 PM
Mitsubishi spindle problem wcopley Mazak, Mitsubishi, Mazatrol 16 11-08-2006 07:06 AM
mitsubishi mrh servo rosli Servo Motors and Drives 1 07-19-2006 02:49 PM
