Old 03-02-2007, 09:18 PM
bjinatj is on a distinguished road
Milling question
I have a cheap HF Mill / Lathe combo. I am trying to figure something out (I am not experienced in either). After purchasing I figured out that the mill only came with a 1/2 drill chuck. I read the documentation and found it used morse taper 2 collets. I purchased some. I then proceeded to buy end mills. Now that I have everything "I thought" I needed I found out that when the mill is completely extended it is 4.5 inches from the bed. How do I get the bit closer to the table.
If anyone cares I have provided a link to the manufacturers pdf.
http://skywasyellow.com/5980.pdf
Thank you in advance for any help!
-Ronnie
Old 03-03-2007, 01:14 AM
wizard is on a distinguished road
You have found the reason (well one of many) that people don't recommend cheap combo machines. Most of them on the market re huge compromises.
Dave
Old 03-03-2007, 10:15 AM
RotarySMP's Avatar
RotarySMP is on a distinguished road
You can also get End mill holders instead of collets. These will etend your mills out by a couple of inchs.
A mill vise will be used on many jobs, also reducing that space.
Regards,
Mark
www.wrathall.com
Milling rigidity question pminmo General Metalwork Discussion 12 05-30-2008 02:29 PM
Milling vise question sierra4sport General Metalwork Discussion 15 05-24-2006 12:04 AM
Milling Brass Question djacob7 General Metal Working Machines 1 06-13-2005 05:19 PM
pcb milling question NickLatech DIY-CNC Router Table Machines 1 03-04-2005 03:49 AM
Just a question about plunge milling. Machine1 Hard and High Speed Machining 4 01-28-2004 09:36 PM
