Old 02-27-2007, 11:02 AM
hydrospin01 is on a distinguished road
looking for a Heavy duty CNC Lathe
im looking for a good heavy duty lathe to handle cutting large punches 6-12 in. in dia. 48-72 in. long made from tool steel, im thinking a Vertical Turret lathe would be best for this, but am having trouble finding info online. Anyone have any comments or recomendations on this
Old 02-27-2007, 11:08 AM
jackson's Avatar
jackson is on a distinguished road
Are you looking for new or used
individual who perceives a solution and is willing to take command. Very often, that individual is crazy.
Old 02-27-2007, 11:13 AM
used
Old 02-27-2007, 11:18 AM
jackson's Avatar
google Vertical Turning Centers
Old 02-27-2007, 11:19 AM
jackson's Avatar
or used cnc equiptment that will get you alot to look through,
Old 02-27-2007, 11:22 AM
jackson's Avatar
If you get a standered lathe you can get steady rest for them and i wold recomend Daewoo 400 long bed i use to run some big parts and that machine has more than enough to do what you need.
Old 02-27-2007, 03:04 PM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
machinetools.com
www.integratedmechanical.ca
Old 02-27-2007, 07:02 PM
gridley51 is on a distinguished road
Why would you want to use a vertical machine for something like this?
Mark.
Old 03-02-2007, 12:17 AM
wizard is on a distinguished road
Mark.
That is something I've been wondering about too. I thought for a minute floor space might be saved but then the parts really aren't that long that it would make a difference. On the other hand going to a vertical lathe would involve a bit of height.
It is an interesting question though - just why a vertical lathe?
dave
Old 03-02-2007, 02:21 PM
A VTL is not the machine tool for this application. A long bed engine lathe, manual or CNC, with a good steady rest and follower rest, is probably the best for relatively long length to diameter ratio workpieces. There are some good CNC flat beds out there relatively cheap. Some are great candidates for updating.
Note: You might consider Mazak M-4 / M-5
DZASTR
Grizzly G0519 vs the Lathemaster heavy duty outlaw paintbal Benchtop Machines 18 09-19-2009 11:57 PM
Converting Heavy Duty Drill Press to Mill: Help! SpeedsCustom Mechanical Calculations/Engineering Design 12 09-12-2006 10:45 PM
Who Supplies of heavy duty tables? adowdel General Metalwork Discussion 14 06-27-2006 09:23 AM
Why is a heavy iron base vital for a good machine? Com Mechanical Calculations/Engineering Design 26 11-29-2005 10:41 AM
