Old 02-26-2007, 01:58 AM
chase78 is on a distinguished road
Options on machines best for reverse engineering
I'm been trying to find a good used machine for the past few months. going back and forth on USED MACHINE vs. New Machine.
My main uses will be
1. 2D & 3D digitizing
2. Milling Aluminum work (nothing more the 6061 AL)
3. Tapping
My Dream would be a large VMC with a table work six of X 30", Y 24", Z 24"
BUT
THIS is what my need are;
A large Z 16" or bigger
A large Y 12" or bigger
I was thing of two other option besides a VMC
1. CNC ROUTER
2. CNC HORIZONTAL MILL ... {then a normal X would be replace my need of a large Z}
Any input?
and if So put lots of links ... I like see what people are talking about
Old 02-26-2007, 10:03 AM
NC Cams is on a distinguished road
A DeVlieg horizontal mill would give you the working area you're craving but the floor space is pretty massive. The machines are not easily found.
A router might suffice, area wise, but I don't know about how accurately it would digitize. THis would depend on the drive system and/or the rigidity.
Probably the most versatile unit would be a/the VMC. SInce it will be ball screw driven and designed for cutting metal, stiffness and accuracy should not be an issue.
I"d go after a VMC...
WE-SIM by Whittlock Engineering millman52 CNC Plasma and Waterjet Machines 4 02-09-2012 04:40 PM
Reverse engineering quadbob PTC Pro/Manufacture 2 04-27-2007 07:54 AM
reverse engineering a BIG stepper drive? DennisCNC General Electronics Discussion 3 11-16-2006 02:49 PM
Reverse Engineering Stepper drive Karl_T General CNC (Mill and Lathe) Control Software (NC) 3 10-08-2006 02:05 PM
help with reverse engineering a couple of found servos's nick mulder Servo Motors and Drives 9 02-20-2006 01:47 PM
