Old 03-06-2004, 06:45 PM
Gold Member
Ken_Shea is on a distinguished road
Where can I find
Any one know where I might be able to locate small spur gears made out of fiber? or better yet composite.
Did a web search and found a company but minimum quantity is 100.
Dimensions
OD .852
Bore: .312
Height: .400
# Teeth: 26
Pressure angle 20 ?
Ken
Old 03-06-2004, 07:39 PM
kenlambert's Avatar
kenlambert is on a distinguished road
what about sdp/si ( 516-328-3300 ) www.sdp-si.com
thanks Kenneth
web-www.lambertsrc.com
Learning CNC
Old 03-06-2004, 07:48 PM
Gold Member
I had looked at them Ken but they do not appear to have the size I need. I may still give them a call on Monday and see if it may be available.
Ken
Old 03-07-2004, 01:00 AM
HuFlungDung's Avatar
Moderator
KenS,
Are you fixing your speed increaser? Better buy a hundred
Old 03-07-2004, 08:03 AM
Gold Member
That sounds very much like a warning
Go pretty quick do they ?
Ken
Old 03-07-2004, 02:38 PM
inthedark's Avatar
inthedark is on a distinguished road
Have you tried Boston Gear?
Kenny
"Plan your work; Work your plan"
Old 03-19-2004, 04:46 AM
Bigfoot1 is on a distinguished road
Where can I find
Dimensions
OD .852
Bore: .312
Height: .400
# Teeth: 26
Pressure angle 20 ?
Ken
Hello , Ken the machine shop that I work for just might be able to help you out . If you havent filled your needs yet let me know and i'll see if I can help . We make all kinds of small or large gears , from just about any material, fibre , delrin, brass, aluminum, steel , cast iron, to name a few.
york and lancaster couny i can not find anyone harolda Mentors & Apprentice Locator 3 08-21-2006 10:37 AM
The most useful software that I cant find! berin General CAM Discussion 3 12-10-2004 11:38 AM
Where to find surplus Tslots or 80/20 samualt 80/20, TSLOTS and other Aluminum Framing Systems 8 11-05-2004 01:04 PM
I hate losing Links, trying to find ones for Thomson Bearings CNC Brute DIY-CNC Router Table Machines 3 01-23-2004 12:16 PM
Find and Replace HuFlungDung OneCNC 12 05-12-2003 06:05 PM
