Old 02-19-2007, 11:24 AM
cncatj is on a distinguished road
coolant recovery vacuum?
hi to all!
I'm in the process to request a vacuum for cleaning coolant tanks
we have been cleaning those tanks by hand! what type of vacuum
you guys suggest?
Old 02-19-2007, 02:05 PM
timlkallam is on a distinguished road
I use a sears shop vac.
Tim
Old 02-19-2007, 05:22 PM
keebler303 is on a distinguished road
A shop vac will work fine. If you want something a little better plumb in a drum so the coolant gets sucked into the drum and not the shop vac. Little extra protection if you are worried about sucking coolant through the vacuum.
Matt
Old 02-19-2007, 07:51 PM
Pres is on a distinguished road
Make sure you use ONLY the foam filter in it.
Don't add a paper filter (it'll just plug up right away)
Note:
If you don't use any filter you'll get quite a bit of spray
out of the exhaust outlet.
You will need to wash (degrease) the foam filter when it gets plugged up with 'slime'.
Depending on coolant dirtyness you might have to wash it out every tank full.
If it is 'clean' coolant, maybe once every 5-10 tank fulls.
A 'tank full' is when the floating ball inside the suction motor rises enough to plug off airflow.
(you'll know it when motor speeds up a bunch - no suction)
Old 02-20-2007, 10:27 AM
Smile
thank's guys !
i'll keep that in mind
Old 02-26-2007, 04:13 PM
bob1371 is on a distinguished road
If looking for something a little more industrial and your working with alot of machines check this out.
http://www.sanborntechnologies.com/sump.html
Bob
Old 02-27-2007, 03:24 AM
ImanCarrot's Avatar
ImanCarrot is on a distinguished road
As an aside...
The Dyson vacuum cleaner was invented by a chap who wanted to reclaim paint from a painting shop. There's no filters, it works by centripetal (some folk call this centrifugal) force and you get 100% suction.. there must be industrial varieties of this system out there that will reclaim your coolant and give 100% suction 100% of the time without filters.
I love deadlines- I like the whooshing sound they make as they fly by.
Old 03-03-2007, 07:44 PM
pepo is on a distinguished road
In the 30 years Ive been in this trade(a good part of it OD & ID grinding) seen a lot of ways to clean a coolant tank. From coffee cans to pump and filter rigs. The best,quickest and easiest was a vac head that sat on a 55 gallon drum. You rolled it up and sucked everything up,sour coolant,chips,sludge,nuts and bolts,that indicator tip you dropped,etc. Only drawback is having a way to handle a full drum,theyre HEAVY.
Vacuum table and vacuum pump garagefela DIY-CNC Router Table Machines 19 01-25-2012 11:30 AM
NSH TF Turbine Oil Recovery plant sinonsh22 Product Announcements & Manufacturer News 0 11-06-2006 01:52 AM
Sino-nsh LV Lubrication Oil Recovery machine sinonsh22 Product Announcements & Manufacturer News 1 10-26-2006 02:05 AM
Sino-nsh Gas Engine Oil Recovery Secondary sinonsh22 Mechanical Calculations/Engineering Design 0 10-13-2006 02:02 AM
How much vacuum? nbuchholz Open Source CNC Machine Designs 4 05-25-2006 05:46 PM
