Old 02-14-2007, 09:36 AM
MattiasCarlsson is on a distinguished road
Turret lathe CNC retrofit?
I found a second hand turret lathe a Lidköping Cr-2 (980 kg) quite inexpensive. I read up on turrets and noted that there are many limitations. No angleslide, no threadcutting more complex setup. But if you would want to retrofit cnc control onto the lathe would you prefere a turrent or an engine lathe? Are there a component in the lathe cnc control that keeps track on the number of revolutions and current angle of the workpiece, which would make it possible to do 'geared-leadscrew' independent thread cutting for example?
Mattias Sweden
Old 01-05-2009, 06:15 AM
WillyK's Avatar
WillyK is on a distinguished road
Lidkoping CR1
Hi Mattias!
You seem to have been in my situation: old Lidkoping
Could you please have a look on my thread of yesterday?
Beste hilsner fra Willy i Oslo
Mattias Sweden
Lathe auto-turret project log kong Vertical Mill, Lathe Project Log 73 03-16-2011 11:12 AM
Lathe Turret Design FritzX Mechanical Calculations/Engineering Design 19 06-15-2010 04:08 PM
Turret Punch Retrofit highendfab General CNC (Mill and Lathe) Control Software (NC) 4 03-30-2006 12:56 PM
LMS Lathe Turret CNCadmin General Metal Working Machines 1 11-28-2005 10:41 PM
