Old 03-03-2004, 06:32 PM
CNC Brute is on a distinguished road
How do I make these things? (General machining questions)
Ok, normally I can visualize things pretty well, but here's where I am having trouble.
1. How you machine a square hole in a block of aluminum?
2. How does knurling work?
3. I've seen 1/2" plate aluminum with 8-12" holes cut in them how do they cut a hole this big?
4. I haven't gotten there yet, but how you get something to .001" of tolerance? It seems to me you can't do it.
5. How do you cut a "ring" (think lathe) around a cylindrical object that is only .062" wide? Isn't that the thickness (roughly) of a bandsaw blade?
6. How do you taper? Especially on a lathe. Crank both handles at the same time?
Thanks guys
Old 03-03-2004, 07:40 PM
duluthboat's Avatar
duluthboat is on a distinguished road
As in all things, there are many ways to skin a cat. My first advice is to find a hands on course for basic machining, mill and lathe.
Drill a hole and broach it, drill hole and saw it, drill a hole and file it, there is even drills that will cut square holes.
You use a knurling tool that has rollers which is forced into the material to cold work the surface into a pattern.
Mount it to a face plate on a lathe and bore it, use a rotary table on a mill, drill a hole and saw it, use a cnc mill.
Its easy with good tools, .0001 is tough.
You grind your cutter to the size groove you want.
Use the compound rest set at angle, use a taper attachment, use a tracer attachment, use a cnc lathe, hang a stock between centers and offset the tail stock.
This is just a few answers to these questions, there are many more. After 30 years I still find new ways of doing things.
Gary
Old 03-03-2004, 10:12 PM
Gold Member
JFettig is on a distinguished road
A good place to start out is this website, I read this thing a few times before I placed my orders.
http://www.mini-lathe.com/
heres for the homier lathe:
http://www.mini-lathe.com/Mini_lathe...er2/Homier.htm
they also have different mini mills reviewed.
Jon
CNC Mini Lathe Plans and Rotary Table kits:
http://jfettigmachines.com
Have things wired....now a few questions DAB_Design Gecko Drives 5 10-08-2004 10:17 AM
Bringing objects together in V19 & general questions rustyolddo BobCad-Cam 1 07-31-2004 09:14 AM
A few honest questions HuFlungDung CamSoft Products 8 06-15-2004 06:24 PM
Lathe machining questions devinchi General Metal Working Machines 5 02-25-2004 10:17 AM
ballscrew repair and some general questions jimbo DIY-CNC Router Table Machines 11 09-27-2003 03:48 PM
