Old 02-10-2007, 10:28 PM
joey1117 is on a distinguished road
any emco5 cnc lathe guru's out there
well i just got the lathe i am using mastercam9 and i can not get the
lathe to receive anything or send.
here is a list of problems
1. looks like it is in metric but i used autocad and it was inch
2. using a null modem cable (sends and receives from my dyna220 mill
just fine)
3.tried using to send,hyperterm. ,mastercam ,ncfree link none worked i
set them all up the same using a sheet from a guy on the cnc zone
4.using the mastercam9 post and did the mods needed to make it work as
per the cnc zone
5.there is a switch on the rs-232 port cable inside the machine going
to the board itself,not sure what that does but i tried it in both
positions still nothing
the null modem cable is a 25 pin on the machine side and 9 pin on the laptop side it works fine with my dyna220 mill
thanks if anyone can help me
joe
emco5 cnc lathe joey1117 General Metalwork Discussion 0 02-08-2007 10:57 PM
Lathe Comparison - Best small lathe for CNC acondit Mini Lathe 48 03-23-2006 08:10 PM
Anyone have a mini cnc lathe or medium sized cnc lathe nymachinist Mini Lathe 6 01-23-2006 09:36 PM
Question for Robotic Arm guru's........ jaxnorth RC Robotics & Autonomous Robots 11 12-29-2005 01:40 PM
New Micro lathe built by me (my second lathe) Stevie General Metal Working Machines 15 11-03-2004 04:56 AM
