Old 02-09-2007, 06:59 PM
mugabe is on a distinguished road
Doubt about X2 spindle
Hi all
I am newbie in mechanics so excuse me for stupid question.
I just got the X2 Sieg mill and measured its spindle deviation with ring indicator . I got about 0.02 at the mill base and i even get more at the end of chuck .
I adjusted mill chuck's draw bar properly . What could be the reason ? Is the spindle to blame ? Most of the screw on the mill are not adjusted properly - those what i have seen on the surface . Then i could imagine what is within ? Do i have to dismount whole machine and mount it again ?
Or may be ask seller to change spindle will be more better?
Yet i measured Y axis as well (ring indicator was mounted to X axis) and get 0.02 micron deviation on the 100 mm. Could it be adjusted ?
Do you think it is time to be disappointed by this product ? I so some really fascinating results posted here by other owners of X2 . Is it something wrong with mine mill?
Sorry for long post but i am just started and there a lot to learn .
Old 02-10-2007, 12:13 AM
most probably i found the problem - the collet for milling was defective with shifted hole. Will change that and go forward.
But another question did arise - what torque must be for spindle bearing preload nut ?
Old 02-10-2007, 07:48 AM
Still problem is there . After changing the collet, playing reduced to somewhat 20 microns at base of milling bit .
Sweo spindle drive? new mill dead spindle Shizzlemah Fadal 13 12-18-2008 12:11 PM
interact 4 spindle drive won't turn on spindle 0041601 Bridgeport and Hardinge Mills 7 06-23-2008 06:51 PM
more rpms for spindle motor and spindle bob1112 Mechanical Calculations/Engineering Design 33 02-10-2007 02:01 PM
chopper doubt mardus Stepper Motors and Drives 19 10-10-2006 06:41 PM
Just had my spindle reground by Spindle Grinding Service! Edster Fadal 30 06-16-2006 11:48 PM
